How low without maxing out alignment
I am looking to drop 2-3" on the front of the '69 1/2 ton. I don't want to convert to disc brakes to use drop spindles just yet. Don't wanna put that much cash into dropping it right now.
So, how much can the springs be cut before alignment becomes an issue? Thanks in advance.
'69 LWB Stepside, 350 with mild mods, and 3 speed on the floor Intentions...383 sbc (in assembly stage), trans is still not a definate (3, 5, or 6 speed?), 3/5 drop, power disc brake conversion...then some body work. |
Old Skool Club
![]() Join Date: Jun 2001
Re: How low without maxing out alignment
Good question. Mine is dropped with spindles and converted to discs. ECE sells a 1-inch shorter spring to make it a total of 3.5 inches lower up front.
I'm thinking that when the front wheels are tucked-in at the top, that too much has been cut/torched and the springs won't support the vehicle....saw an '88-98 SWB the other day and I know the inside of the tires had to be wearing like crazy. There have been many of the '67-72's that had cut springs on them, so somebody will let you know what worked for them....and what didn't work for others.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. Last edited by ChevLoRay; 03-31-2009 at 07:22 PM. |
A guy with a truck
3" spring drop is generally the limit for alignment adjustability. Cut one full round off the bottom of your springs- should give you 2-2.5" and still be alignable...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
I took a coil and a half off the front coils of my 70', (w/ 3 spacer blocks in back - Rear coil suspension), way back in 91-92. It dropped the front 3 inches or so. I drove the truck for 5 years without any problems.
![]() Here's how it sat. If you look at the front wheel/tire it sits straight at ride height. |
Watch out for your cornhole !
![]() Join Date: Jun 2003
I've done a good number of trucks with 3 inch drop front springs. As long as the suspension is pretty tight and not worn too much, you can get enough shims in place to get back into specs.
If your control arm bushings or ball joints are worn though, you likely won't be able to get enough adjustment.
Thread Tools | |
Display Modes | |
