Old 03-31-2009, 10:33 PM   #1
ole6320
6 lug to 5 lug rear
Hi everyone I have a 86 c10 and i have a 86 12 bolt posi laying around but it has the 6 lug bolt patter. I have a 10 bolt non-posi under the truck right now, what is involved on maiking the rear end a 5 lug? Can I just swap the axles out? Or is it more complicated than that? Thanks!
1986 Chevy C-10 2WD Long Box
406 SBC 12.5/1 compression
E-85 monster!
ole6320 is offline   Reply With Quote
Old 04-04-2009, 11:24 AM   #2
ole6320
Re: 6 lug to 5 lug rear
ttt
E-85 monster!
Old 04-04-2009, 11:34 PM   #3
THE UGLY
THE UGLY's Avatar
if you can find a 5 lug 12 bolt at the junk yard the axle will bolt right in where the 6 lugs are. you will nead the drums for the 5 lug brakes and make sure the drum diamiter is the same
THE UGLY is offline   Reply With Quote
Old 04-05-2009, 12:02 AM   #4
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
As far as I know, you can swap the axels. 12 bolts were available to 82.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 04-05-2009, 01:03 AM   #5
sailed2japan
Jonny
sailed2japan's Avatar
Ok, here's what I've heard. Swapping 5 lug axles into a 6 lug axle won't work, I think because of the length of the axle, but this is messing with a 60-72 12 bolt. The 73+ may be different. However I've been told that you can swap the carriers around.
Now, what I would do is grab a complete 5 lug axle and figure out which parts to mix and match.
1966 C30, Cummins, stacks, and a flat bed in progress...
"Honor.....simply put,
A veteran - whether active duty, retired, national guard or reserve is someone who, at one time in his life, wrote a blank check made payable to 'The United States of America', for an amount of 'up to and including his life.' That is Honor, and there are way too many people in this country who no longer understand it."
-AEC Hundley USNR
sailed2japan is offline   Reply With Quote
Old 04-05-2009, 04:17 AM   #6
gchemist
gchemist's Avatar
Any 8.5" 10 bolt or 12 bolt have interchangeble axels. Including the back plates for the brakes. The pinion and ring won't interchange. Same for a posi or gov-lock.
Old 04-05-2009, 04:22 AM   #7
gchemist
gchemist's Avatar
The axel shaft interchangebility is for any 10 or 12 bolt after '70. Older models won't interchange like sailed2japan states.
Old 04-05-2009, 08:34 AM   #8
larrystone
larrystone's Avatar
Is it possible to just change the front brake rotors to six lug using the existing brake caliper?
I see sets of OEM six lug 16" GM alum wheels on CL going cheap.
1992 C1500 WT LWB 4.3TBI 700r4 4.10 limited slip= Work Truck
1986 C10 Custom Deluxe LWB 4.3-4V TH350C 2.73 ac cruise tilt= Cowboy Cadillac
larrystone is offline   Reply With Quote
Old 04-05-2009, 12:44 PM   #9
sailed2japan
Jonny
I was reading on the 67-72 board that someone makes a specialty rotor that works with the hevy duty 1/2 brakes to convert to 6 lug. It only works if you have the 1.25" rotors, though.
-AEC Hundley USNR
Old 04-05-2009, 11:15 PM   #10
THE UGLY
THE UGLY's Avatar
be carefull there is a truck 12 bolt and a car 12 bolt and they are different.
Old 04-06-2009, 09:25 AM   #11
sailed2japan
Jonny
Yes, definately, but I haven't figured out which one is in an El Camino....j/k
-AEC Hundley USNR
Thread Tools
Display Modes
