454 MAKES IT ROAR
Water pump hose
Does anyone have any ideas what I could replace this crappy hose with? I mean is there anyone making a specific & more decorative hose out there for this?
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger |
Nothing to see here.....
![]() Join Date: Jun 2007
Re: Water pump hose
Nigel,
I know Classic Industries produces a specific big block water pump bypass hose like that. It is the correct bend angle and length. You may try your favorite board vendor, I'm sure they would have something as well. Good luck, Mate!!
Doug ![]() ![]() The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson Last edited by tcb-1; 04-03-2009 at 08:44 AM. |
454 MAKES IT ROAR
Re: Water pump hose
Thanks Doug, just had a look, the one they keep seems to just have a slight curve as appossed to a 90 degree, which it looks like it should be.
Re: Water pump hose
I used to sell those when I would at the Zone years ago.
-Scott- |
It'll Buff Out!
![]() Join Date: Apr 2007
Re: Water pump hose
"Instructions are just another mans opinion" Become a Supporting Member http://67-72chevytrucks.com/vboard/payments.php Man Card Rules http://67-72chevytrucks.com/vboard/s...d.php?t=634550 72 Chevy Cheyenne Super 400 LWB |
454 MAKES IT ROAR
Re: Water pump hose
Braided hose seems to be the best option here as far as making it look a little better. I suppose I was hopeing that there was some sort of Billet type Elbow that would connect the two instead of 5" of hose.
Thanks guys....
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger Last edited by eightbanger; 04-03-2009 at 12:49 PM. |
It'll Buff Out!
Re: Water pump hose
The only other thing is can you make it out of AN fittings? 90 deg down and in
AN fitting on the water pump?
Active Member
Re: Water pump hose
This is what I run on my truck - I think it is the slickest device out their for the cross over hose
http://www.coolflex.com/cfm/store.cf...t=3&mode=parts
1968 SWB 454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts 781 heads Ported with 2.19/1.88 SSTvalves Lunati 60204 cam, Micro Trol lifters, Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition Holley 770 Street Avenger carb,Headers armor coated Built by Watson Ruppel Performance in Sarahsville Ohio. Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall 12 Bolt Eaton Posi 4.10 Richmond Gears moser axles ![]() 18.5" x 31" Hoosier Pro Street Radials ![]() ET Classic 5 Wheels - polished Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone) Custom Paint & Body Work Special thanks to my wife, my son and my money tree ![]() |
454 MAKES IT ROAR
Re: Water pump hose
This is exactly what I was hopeing for 1968SWBBigBlock Thanks for the link Just got to figure out which one I need.
Cheers mate. ![]()
Re: Water pump hose
Nigel,
What are you doing up?!! A wee bit late right now, yes?
Doug ![]() ![]() The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson |
454 MAKES IT ROAR
Re: Water pump hose
Anyone know how to tell if I have a long or short water pump? so that I can buy the correct length Bypass Hose
Between Trucks...
Re: Water pump hose
That looks like a short water pump to me, but might want to see what the big block experts have to say.
Beat it to fit, Paint it to match... ![]() |
#13 |
454 MAKES IT ROAR
Re: Water pump hose
Anyone else?
#14 |
![]() Join Date: May 2004
Re: Water pump hose
It looks like a short pump. If there is no space between the water pump & the timing cover, then it is a short pump. Long pumps have about 1/2 to 3/4 inch between the pump & the timing cover. SBC are the same as BBCs.
#15 |
454 MAKES IT ROAR
Re: Water pump hose
Sinister & 53burb.....Cheers guys!
#16 |
Formerly- 1972SuperCheyenne
![]() Join Date: Oct 2008
Re: Water pump hose
If you can put your fingers between the timing cover and water pump it's a long pump. If not it's a short pump.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
#17 |
Chevy Lover Till The End.
Re: Water pump hose
Here is a picture of the water pump on my big block. See the difference
1969 Chevy SWB Big Block - Under the knife as of 12/26/2011 1989 Chevy Silverado, 4X4 - Daily Driver 1996 Chevy Suburban K1500 - 4-Wheeler, Campin Truck 1968 Chevrolet Impala Sport Coupe - 327/350hp, TH400, all original. Members I've met: BamaBaxter, My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=500359 |
Thread Tools | |
Display Modes | |
