Old 04-09-2009, 08:44 AM   #1
72-c20
Packrat
72-c20's Avatar
a little work on my '72...
New radiator, new battery tray, added a trans cooler, and decided I may as well do my grill too....
center section was a junkyard piece with cracks and broken tabs. epoxied it all back together. cleaned and painted a satin black. swapped out to a better bow tie. had a spare shell, and smoothed out the dents/twists in it enough to make it usable, and cleaned and repainted the black around the headlights.... just have to mount my junkyard chrome bumper now....
gone: --'07 Tahoe LTZ 4WD
--'68 Firebird 400 Convertible
gone: --'72 Chevy K20
72-c20 is offline   Reply With Quote
Old 04-09-2009, 08:46 AM   #2
72-c20
Packrat
72-c20's Avatar
Re: a little work on my '72...
and the original look....
I think the grill shell I took off was aluminum, but the used one I put on was chromed steel.....
Old 04-09-2009, 09:06 AM   #3
LockDoc
The Older Generation
LockDoc's Avatar
Looks a lot better now. Put up another pic when you get the bumper back on.
LockDoc
Leon
Old 04-09-2009, 09:30 AM   #4
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Nice upgrades for sure.
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 04-09-2009, 12:40 PM   #5
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Nice work!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 04-14-2009, 09:29 AM   #6
72-c20
Packrat
72-c20's Avatar
LockDoc
got the bumper back on Sunday night late. hopefully I can get a pic today since it stopped raining....
the JY bumper had remnants of some fog light brackets, so since the holes were already there, I put on some New vintage style fogs lights
Old 04-15-2009, 08:49 PM   #7
72-c20
Packrat
72-c20's Avatar
so here's the final product...
I also got my tow hooks installed...
Old 04-15-2009, 09:07 PM   #8
ratrod67
ratrod67's Avatar
Big improvement!! Very nice!!
ratrod67 is offline   Reply With Quote
Old 06-30-2010, 02:45 PM   #9
72-c20
Packrat
72-c20's Avatar
been a while since anything was done.... the crate engine that was in it blew, so now it has another new crate engine via warranty. Then I had an electrical prolem with the power wire to the HEI Distributor... melted some wires together to the ignition switch, so it wouldn't shut off....
so, wire to the Disty was replaced along with an additional in-line fuse, and 2 wires from the fuselock to the ignition switch were replaced...
since I've got the cluster pulled out, I finally combined it with the refurbished one I worked on a year or so ago, and replaced the printed circuit board, as I found mine had some "melting" all lightbulbs tested/replaced. now finishing up the cluster wiring.
need to "re-loom" the under-dash harness and look at the fan switch wiring a long as I'm there..
I also picked up a couple of nice doors for it too, and am gonna try and get them on it....
Old 06-30-2010, 08:11 PM   #10
LockDoc
LockDoc's Avatar
Sounds like you are making some progress on it. Keep up the good work...
LockDoc
Leon
Old 07-07-2010, 03:40 AM   #11
72-c20
Packrat
72-c20's Avatar
hmmm. previous owner had installed a toggle for the heater blower. way back when I rebuilt my control unit, I bought a new switch, but it still wouldn't work... whadda ya know. the fuse appeared good, but was burnt off at the end apparently. new fuse, and I have a 3 speed fan again, and the toggle has been removed....
Old 07-16-2010, 04:31 AM   #12
72-c20
Packrat
72-c20's Avatar
new dash pad is in
got my updated intrument cluster in (LED bulbs, tach, Voltmeter, and clock
new glove box in.
fixed light on heater control unit
replaced turn signal/hazard switch assembly. original one had the hazard switch busted off...
I cut a slot in the printed circuit for the tach wires to go through, and it worked out well. The clock and VM out of the 76 Chevy work well, too...
next up is replacing the doors....
Old 07-21-2010, 01:44 PM   #13
72-c20
Packrat
72-c20's Avatar
started replacent of the drivers side door... got the door off and hinges off, now waiting for new hinges. the originals were prettworn, and the pin was busted off inside, with just a little puvot point holdng it together... lucky the door didn't fall off...
I attempted to get the pins out, but my "pounding base" isn't very good sinc I moved houses...
I needed a diff window regulator for the door, and decided the original one was worn enough to warrant a new one, so that's ordered...
also decide to replace the rocker while I was there. the one that was there, was jus riveted/screwed in place from a previous owner, and until I'm able to do the full proper body work the cab needs, the new one will be a temp installed in the same manner...
and I found the fuel gage wire had broken, ending the search for why the gauge woudn't work....
Old 07-21-2010, 04:01 PM   #14
marks1972
marks1972's Avatar
nice looking truck
Mark
1968 C-10 SWB 307/munci 4spd/411possi 1986-1990
1972 Cheyenne-10 LWB 350/TH350
IF SHE WHOULD HAVE KEEPT THE SHIRT ON THEY WOULDNT HAVE BROKEN UP THANKS ADAM SANDLER
U. S. Navy Seabee
"CAN DO", "The difficult we do at once. The impossible may take a little bit longer.","We Build We Fight", "Work Hard Play Hard"
marks1972 is offline   Reply With Quote
Old 07-21-2010, 05:02 PM   #15
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Nice progress Mick!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 07-26-2010, 09:47 AM   #16
72-c20
Packrat
72-c20's Avatar
OK. a bit more done.... along with trimming the hedges and othe yard work
replace the rocker and got the new hinges installed, then the solid replacement door...
after I got the door hung and lined up, then I moved on to a new window regulator. Now that job was a PITA. I tried following the instructions in the FAQ. not sure if it's because it's a 72 with the screw/brace under the vent window or what, but it sucked...
cleaned up a set of door panels I got from DieselWrencher (thanks!) They had a woodgrain panel so the scrollwork was still perfect, and not faded/discolored.
Then I used some Krylon Fusion pain for plastic....
I also have new black armrest/handles to install...
Old 07-26-2010, 10:16 AM   #17
vectorit
What?
vectorit's Avatar
Good work on getting things back together!
Truck looks great!
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 07-26-2010, 10:18 AM   #18
VA72C10
VA72C10
VA72C10's Avatar
nice progress!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 07-26-2010, 12:49 PM   #19
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
keep working it.....
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 07-26-2010, 03:42 PM   #20
bigguy69
dazed and confused
bigguy69's Avatar
lookin good!
members met: redbaron69, billsbowtie,nc67
bigguy69 is offline   Reply With Quote
Old 07-26-2010, 05:09 PM   #21
RCbowtie69
RCbowtie69's Avatar
looking good,keep up the hard work
RCbowtie69 is offline   Reply With Quote
Old 08-02-2010, 09:49 AM   #22
72-c20
Packrat
72-c20's Avatar
finished up the door, and drained the trans, and put on a new gasket. no more tranny leaks...
took it on a couple hundred mile round trip cruise yesterday for a family reunion...
fuel gauge still not working though. it's got a new sender, new wire from sender to fuse panel, and have tried 2 different guages... looks like I'll be checking the rest of the wiring....
Old 08-02-2010, 07:16 PM   #23
VA72C10
VA72C10
VA72C10's Avatar
try the printed circuit....since you've isolated a lot of the other potential issues....check out the back for any breaks in the circuit...
Old 08-22-2010, 12:16 AM   #24
72-c20
Packrat
72-c20's Avatar
the printed circuit was a good one I just replaced... I got some new resistors for both e fuel and temp gauges....
might get at them this week. today I installed a 15,000 lb class IV hitch.. it was a beast!
Old 08-22-2010, 12:26 AM   #25
BlackTopMotors
Looking good! Keep up with the pics as you progress! Nice job on door panels too!
BlackTopMotors is offline   Reply With Quote
Thread Tools
Display Modes
