Old 12-23-2002, 09:51 AM   #1
Jason Roberts
Tranny down shift problems.
Hey guys I was just wondering if any one could tell me whats up with my 350 tubo.
It goes through all the gears fine but it will not down **** when i slow to 35,It will only down shift if I slow to under 20It is becoming a real pain in the ass espesially on on ramps I have to manually shift it down to second.
I changed the govener from another tranny but all that did was change the shift points any help would be greatly apreciated.
Jason Roberts is offline   Reply With Quote
Old 12-23-2002, 01:57 PM   #2
J-Spec C10
Whats this wire for?....
J-Spec C10's Avatar
Have you checked the fluid?
What color is it?
Kyle
CANADIAN CONNECTION
'82 C10 Resto-Custom--> * 2 1/4" manifold back dual exhaust with Hooker Aerochambers & High Flow Cats *Taylor Ignition Wires *Centerline 15" Telstars with 32"x10" mudders
J-Spec C10 is offline   Reply With Quote
Old 12-30-2002, 10:35 PM   #3
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Have you solved your problem?
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 01-01-2003, 03:16 AM   #4
outlaw
your kickdown cable is hooked up
outlaw is offline   Reply With Quote
Old 01-02-2003, 03:00 PM   #5
Jason Roberts
still no luck withmy down shift prob
Tried turning mod screw in but only got worse.any other suggestons would be great.
Old 01-03-2003, 07:40 PM   #6
Jason Roberts
can anyone tell me what the wire conector on the side of the trannny is is that my problem I don,t have it hooked up?
Old 04-04-2003, 07:36 PM   #7
gmc7286chevy
Does it have a lock-up torque convertor?
gmc7286chevy is offline   Reply With Quote
Old 04-04-2003, 07:46 PM   #8
Slonaker
Insert Witty Text Here
Slonaker's Avatar
The wire on top pf the trans, if it is a TH-350c controls the lockup. I am guessing that the wire on the side must be for backup lights, because I can't think of any wires.
It sounds like your kickdown cable is broken, not hooked up, or not adjusted. I used to have a th-350 in a Cutlass that had the same symptoms. It was just a kickdown cable out of adjustment.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 04-04-2003, 10:49 PM   #9
CHaingKaiShek
I love goooooold!
CHaingKaiShek's Avatar
I had a similar problems with my truck when I first picked it up. Turned out I just needed to adjust the kick-down cable, and it worked properly from that point on.
Jeff
"Musha ring dum a doo dum a da
Whack for my daddy-o
There's whiskey in the jar-o."
CHaingKaiShek is offline   Reply With Quote
Thread Tools
Display Modes
