Old 04-12-2009, 02:51 PM   #1
gmclowsierra
fuel pressure reg mounts
is anyone here runnin a holley blue electric pump with the regulator and an edelbrock carb? if so can you post a pic of where you have the reg mounted. even if you dont have a pic can you still tell me where you have your located? thanks for the help JOE
gmclowsierra is offline   Reply With Quote
Old 04-12-2009, 07:33 PM   #2
bigblock73
yeller
bigblock73's Avatar
Re: fuel pressure reg mounts
I am running a mechanical pump, here is where mine is located.
I was going to run a Holley elec pump, but my local speedshop did not recommend Holley pumps, due to their consistent failure and ability to send broken parts thru the fuel system.
bigblock73 is offline   Reply With Quote
Old 04-12-2009, 08:04 PM   #3
S10Fan
Old Heap Driver
I'm running the Holley red pump but planning to switch to a mechanical pump soon. Anyway, my regulator is mounted to the intake and connected to a Holley carb. The Edelbrock carb fuel line routing would be very similar.
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 04-12-2009, 08:20 PM   #4
babyJay
Arrived on a Pale Horse
babyJay's Avatar
All I can say is.....Jeff, that's awesome!
Jason
87 V30 350TBI/400 White w/Boss V-plow
89 R3500 CC SRW
babyJay is offline   Reply With Quote
Old 04-12-2009, 08:23 PM   #5
kelsfine69
18 Till I Die
kelsfine69's Avatar
Mine, If it helps
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 04-12-2009, 08:31 PM   #6
bigblock73
yeller
bigblock73's Avatar
Thanks for the compliment. I am trying to hide as much as I can under the hood, thought tucking the regulator up close to the carb under the air cleaner would help. The bracket was easy to make, bending the lines was another story!
Old 04-13-2009, 09:49 AM   #7
babyJay
babyJay's Avatar
Cant wait to see it driveable....
Jason
89 R3500 CC SRW
Old 04-13-2009, 09:11 PM   #8
gmclowsierra
those ideas are all well and good but im looking for edelbrock carbs.
Old 04-13-2009, 09:20 PM   #9
OrangeAnimal
OrangeAnimal's Avatar
Edelbrock could use the same kinda of mount. You just don't need the dual outlets. The one on bigblock73's would work for you as just use a 90* fitting to hook up the gauge to. Otherwise it will work the same. Hope this helps.
82 Chevy SWB "OrangeAnimal" Lot of Goodies! Sold
93 GMC 1500 "Angry Red" 383 TBI Powered Fun! 300hp/410ft.lbs.
09 Yaris wife's daily.
OrangeAnimal is offline   Reply With Quote
Thread Tools
Display Modes
