Old 04-15-2009, 07:44 PM   #1
BYoung35
Sway bar question
Did 67-72 come with sway bars ? The reason i ask is i have 3 trucks and only 1 has a sway bar but it doesn't look factory installed.
Thanks for your help.
BYoung35 is offline   Reply With Quote
Old 04-15-2009, 08:21 PM   #2
BYoung35
Re: Sway bar question
I ment to say did all of these model trucks have them ?
Old 04-15-2009, 11:04 PM   #3
N2TRUX
Happy to be here
N2TRUX's Avatar
I'm not sure on the 67-72's, but 73-87's it was optional.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 04-18-2009, 11:34 PM   #4
Joemomma1
Joemomma1's Avatar
I just pulled a whole set up from a 72 C20. The brakets for the frame had rivets, the arms had bolts. Im pretty sure its factory. It looks to be 1.25" in diameter.
Joemomma1 is offline   Reply With Quote
Old 04-19-2009, 10:17 AM   #5
truckpoorpackrat
I know that 69-72 had swaybar option on 2wd trucks. Not sure about before that.
truckpoorpackrat is offline   Reply With Quote
Old 04-19-2009, 11:47 PM   #6
project 67 sub
project 67 sub's Avatar
my 67 burb didnt have one at all, but it sure does now
project 67 sub is offline   Reply With Quote
Old 04-21-2009, 08:38 AM   #7
tater71c
my 71 c10 doesn't have one but it has the holes in the in the control arm to mount one
tater71c is offline   Reply With Quote
Old 04-21-2009, 10:30 AM   #8
Tony@AirRideTech
Junior Member
it was an option on the 63-72's and became much more prevalant on the 73+. If I rmember right, it was pretty much standard equioment from about 75 or 78 and up. The problem with the factory sway bar on these trucks, despite the ingenious suspension design itself.... the sway bars flat out sucked if you were running the truck at anything other than stock height. If you are lowering the truck, just plan on replacing the sway bar.
Tony@AirRideTech is offline   Reply With Quote
Thread Tools
Display Modes
