Old 04-20-2009, 01:02 AM   #1
tecky11
cleaning axles?
moderators, sorry if i put this in the wrong spot, just redirect and let me know.
Everyone else what is the best way to clean road grime off of a 32 year old axel?
tecky11 is offline   Reply With Quote
Old 04-20-2009, 07:41 AM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: cleaning axles?
Pressure washing is a good start. From there sand blasting gets the axle nice and clean. A good coat of primer, followed by your color of choice and your set to go.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 04-20-2009, 08:56 AM   #3
tecky11
Re: cleaning axles?
only problem is it is still attached to the truck
Old 04-20-2009, 10:47 AM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: cleaning axles?
Unbolt the track bar, and jack the truck up as high as possible. Get some Goggles, a poncho and get busy...
Articles-
"Refining Sierra"
Old 04-20-2009, 11:21 AM   #5
Houston54
Re: cleaning axles?
A knotted wire wheel on an angle grinder works well on the solid crud that powerwashing can't get off. Wear a faceshield, gloves and ear protection though as those wheels like to shed. You will need a bath afterwards.
If you want it spotless you will probably have to remove it from the chassis but that is pretty easy. The hardest part is re-bleeding the brake lines when you put it back in.
Houston54 is offline   Reply With Quote
Old 04-20-2009, 12:07 PM   #6
combustion
Re: cleaning axles?
hahah there you go. nothing fancy.
If it`s 3.73 ratio you will spint the wheel 100 times to the driveshaft`s 373 times.Or,if you`re lazy,you could just spin the wheel once and the driveshaft will spin 3.73 times.Or, 3 and 3/4 turns.And if you`re real lazy,I can sell you a tab for whatever ratio you want.
Or,you could read all the suggestions and try those.It`s been well explained,I think,already.
combustion is offline   Reply With Quote
Old 04-20-2009, 12:10 PM   #7
tecky11
Re: cleaning axles?
what is a trackbar
Old 04-20-2009, 02:43 PM   #8
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Re: cleaning axles?
Now... oven cleaner will teardown grease, but you have to be careful where you apply it.
Does anyone know how simple green will do on grease? I doubt that it is strong enough... but wanted to throw it out there as it's a great cleaning solvent and fairly harmless.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 04-20-2009, 03:11 PM   #9
Shane
Shane's Avatar
Re: cleaning axles?
Gunk Engine Cleaner does a pretty good job if you don't want to use something as strong as oven cleaner. Spray it on, then drive down to the local "you-wash-it" car wash ... use the hot soap and then rinse.
Shane is offline   Reply With Quote
Old 04-20-2009, 06:45 PM   #10
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: cleaning axles?
Oven cleaner works well but is very caustic and I don't recommend it as it is too easy to get it where it shouldn't be.
Shane is correct. I have used Gunk brand "Engine-Brite" with great success. The only caveat is it really needs the pressure and hot water from the quarter car wash. Doing it the drieveway with cold water and hose pressure is not very effective.
Articles-
"Refining Sierra"
Old 04-20-2009, 07:24 PM   #11
tecky11
Re: cleaning axles?
how about cold water with a 3000 psi pressure washer
Old 04-20-2009, 07:33 PM   #12
Shane
Shane's Avatar
Re: cleaning axles?
you gotta put something on it to break down the grease chemically or you are just gonna smear it around more ...
Old 04-20-2009, 09:15 PM   #13
protrash64
Resistance is Futile
protrash64's Avatar
Re: cleaning axles?
I use Oil Eater. It can be cut or used full strength. It does a good job but you will still need to remove the heaviest crud with a scraper, wire wheel, or pressure was h it e few times. Afterward, you can use the Oil Eater to wash your clothes.......
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 04-20-2009, 10:50 PM   #14
scotts62
One day...
scotts62's Avatar
Re: cleaning axles?
Superclean at your local Oreillys and then to a car wash works really good.
Scott
93 crew cab build
Project 62
Old 04-21-2009, 01:53 AM   #15
tecky11
Re: cleaning axles?
awsome, thanks !!!
Old 04-23-2009, 12:44 AM   #16
willyCJ
willyCJ's Avatar
Re: cleaning axles?
I've always done well using Purple Power. Most of the other suggested products are pretty environmentally unfriendly. Purple Power (and Simple Green) break down and can go down the drain.
I've used the Engine Brite products before. They work, but I'm just as happy using more Purple Power.
I've also had success blasting grease with brake cleaner. You'll go through quite a bit of it, but it does well in welded joints where its just awkward to get in the spot. I'm not sure if it dissolves the grease or just blasts it away. Either way, it gets grease off the part.
1970 Shortbed C10
Parts I need:
Headlight Switch, Headlight retainers, Bezels (found, thanks jc)
wiper arms, wiper switch (found, thanks jc)
Carpet (blue/black preferred)
about half the e-brake cables (for a shortbed truck)
willyCJ is offline   Reply With Quote
Thread Tools
Display Modes
