Old 04-23-2009, 01:15 PM   #1
wancosc356
I Like Mine With No Shine!
wancosc356's Avatar
Body/Frame Swap Question
Can you swap a 1967-1972 cab and bed onto a 1982 frame and suspension? If so, does it involve welding new mounts or can you just swap it over?
1/2 ton to 1/2 ton. 2wd and short bed both. Thanks.
wancosc356 is offline   Reply With Quote
Old 04-23-2009, 01:25 PM   #2
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
Re: Body/Frame Swap Question
The frames are quite a bit different and would require a fare amount of fabbing ,but you can swap out complete front suspensions with not a lot of trouble.The rear can be inner axled if its a 70 or redrilled to 5 lug if older.
sneakysnake is offline   Reply With Quote
Old 04-23-2009, 03:40 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
yep, the suspention will fit the old frame, the new frame won't fit the old truck.
If it was a 4X4, it would be doable.
Old 04-23-2009, 05:39 PM   #4
wancosc356
wancosc356's Avatar
oh ok. well that sucks. on a side note, what is the advantage of swapping out the newer suspension on the older truck? Thanks for the info.
Old 04-23-2009, 06:20 PM   #5
OARNGESI
OARNGESI's Avatar
Disk brake and cheaper parts
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 08-20-2012, 12:00 AM   #6
Jeremy69
So do the holes not line up or something? I ask because I have a chance to get a rolling frame that was an 82 6.2 diesel. It has the heavy springs and the high speed rear end. I have been looking for a short bed frame to swap my cab over to and was curious.
Jeremy69 is offline   Reply With Quote
Thread Tools
Display Modes
