Old 04-28-2009, 05:48 AM   #1
z400rider8787
bed side removal tips
so i've been removing my bed sides, or at least attempting to but im running into a few problems. after i get about 2 or 3 turns on the nut the bolt just spins in the sheet metal. i ended up cutting a few off but this is very time consuming and i run the risk of damaging something. does anyone have any tips to keep them from doing this? thanks
z400rider8787 is offline   Reply With Quote
Old 04-28-2009, 07:56 AM   #2
otsenre
otsenre's Avatar
Re: bed side removal tips
I used my impact and instead of trying to loosen I tightened further till they broke off
otsenre is offline   Reply With Quote
Old 04-28-2009, 12:24 PM   #3
Green Machine
Green Machine's Avatar
Metal floor ? Just tighten them they will twist off, best advice I was ever given about those beds. Also where the tubs bolt to the sides, get or borrow an oxy/acetl torch, no mapp gas or propane here. Quickly heat the bolt heads until they are cheery red and let them cool for an hour or so. This will break the rust loose so they won't twist off in the bed sides.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 04-28-2009, 05:05 PM   #4
jholley
jholley's Avatar
Dont forget there are spot welds in the places marked in the pic that you will have to cut.
Jim
Garage fillers...
85 Chevy C10 Silverado LWB
07 Nissan Altima
2006 Mini Cooper S
jholley is offline   Reply With Quote
Old 04-28-2009, 07:18 PM   #5
jamie72
jamie72's Avatar
tac weld the the bolt heads then spray a little penatrating oil on them...
jamie72
72 BB cheyenne -- Restoration getting started..
member #807
http://www.myspace.com/whitetailobsession
www.antlertalk.com
jamie72 is offline   Reply With Quote
Old 04-28-2009, 07:32 PM   #6
sick69
sick69's Avatar
When I was removing my tubs I had the same problem. I welded a 1/4" rod across all of the bolt heads to hold them in place. The rod was about 36" long so I just laid it on the bolt heads and welded away.
Obviously I replaced the old ones when I put it back together. After all the nuts were off all the bolts cam out at once as one piece and straight into the trash!
Frank
70 chevy lwb c10
454/th400 and a 9" rearend
suicide doors, marker light fuel fill, 4" cowl , mini tub
sick69 is offline   Reply With Quote
Old 04-29-2009, 03:34 AM   #7
z400rider8787
alright thanks guys, im gonna try the spin them off with the impact technique. that should save me a ton of time, i was gonna tack weld the heads on but i have a small problem, i dont have a welder lol
Old 04-29-2009, 06:54 AM   #8
19673ontree
CAN'T FIX NOTHIN
19673ontree's Avatar
what he said !
1967 C10 Shortbed Fleetside Small back glass
6 cyl 3spd on the tree 3.08 gears
underdash AC
19673ontree is offline   Reply With Quote
Old 04-29-2009, 09:02 AM   #9
idonutn0
This worked for me too.
idonutn0 is offline   Reply With Quote
Old 05-01-2009, 03:20 AM   #10
z400rider8787
holy crap! worked great. i wish i would have asked before i started. thanks guys
Thread Tools
Display Modes
