Old 04-28-2009, 08:34 PM   #1
bw4sale
bw4sale's Avatar
Brake questions
Ok, my pedal travels a lot before there's resistance. When it hits, it's very hard. I pulled my cap off the MC and the front half was completely full, back was almost empty. I seem to remember it being this way before when I first got the truck about 2 years ago. I think I filled the back then and it hasn't really been driven since then. Do I have a leaky cylinder or something? I pulled the back drums just to inspect a little. The drums look good. The pads looked pretty new. One pad was more worn than the other on my passenger side. What does that mean? How do I inspect the wheel cylinders and the other inner parts? Overall it looked better than I thought it would. Thanks.
BRENT
-'68 Stepside Project
-'98 Z71 Daily Driver
-Enough extra parts to build another truck and a half
bw4sale is offline   Reply With Quote
Old 04-29-2009, 07:42 AM   #2
bw4sale
bw4sale's Avatar
Re: Brake questions
bump. Anyone?
BRENT
Old 04-29-2009, 10:05 AM   #3
rlm316
rlm316's Avatar
Re: Brake questions
Need more info on the truck, year, type of brakes and power/non power. Without the info, check the front brakes for a leak. Probably a wheel cylinder if drum type.
rlm316 is offline   Reply With Quote
Old 04-29-2009, 10:08 AM   #4
mvfd70
mvfd70's Avatar
Re: Brake questions
Sounds like it could be leaky wheel cylinders on the rear brakes. If the shoes are new and the drums are still good, then I'd change the wheel cylinders on both sides. Then bleed the brakes real good. Start with the simple stuff and work up from there. Also while you're under the truck, inspect the rubber brake hoses. If they look old, cracked, and/or stretched I would replace them as well. Have someone push on the brake while you look at the hoses and see if they stretch. You can also see if you see any fluid leaking anywhere while you do that. Couple cans of brake cleaner would be a good idea too.
1978 Chevrolet Silverado 3/4 ton 400 small block.
2000 F-250 Powerstroke
2002 GMC Yukon Denali XL
mvfd70 is offline   Reply With Quote
Old 04-29-2009, 10:10 AM   #5
mvfd70
mvfd70's Avatar
Re: Brake questions
Oops. What rlm said too. I was assuming that you have disc brakes on front.
Old 04-29-2009, 10:16 AM   #6
haysonj
haysonj's Avatar
Re: Brake questions
If its a wheel cylinder leaking that much fluid you would be able to see it running down the inside of backing plate. Might want to check all the fittings and hoses.
69 Chevy 4x4 383 Power
haysonj is offline   Reply With Quote
Old 04-29-2009, 10:30 AM   #7
bw4sale
bw4sale's Avatar
Re: Brake questions
Thanks guys. It's a '68 non power with drums all the way around, but I've got the stuff to convert to power and I'm hoping to go to disk up front soon as well. I think I'll go ahead and replace the rear cylinders anyway and inspect all the hoses.
BRENT
Thread Tools
Display Modes
