Old 04-30-2009, 12:34 AM   #1
Why buy a ford?
Block Huggers Maybe? Help me?!?!?!
Can someone help me?!?!?!? I have a 1971 Chevy C-10 with a 350. I want to get some stainless steel block hugger headers but i am not sure if they will clear the frame rails, or motor mounts. Does Any help would be greatly appreciated.
Why buy a ford? is offline   Reply With Quote
Old 04-30-2009, 01:30 AM   #2
Why buy a ford?
Re: Block Huggers Maybe? Help me?!?!?!
If this help... i forgot to mention that everything is stock pretty much, such as motor mounts, and angle spark plugs.
Old 04-30-2009, 06:16 AM   #3
lax54650
i had purchased a set of block huggers.. they cleared frame nicely but dumped right on crosmember . it would have been nearly impossible to get down pipe attached. in an earlier post i was told to get 4wd block hugers. they dump farther back. i bought a set of "chevelle" headers at swap meet. they sweep back nicely but just rub along frame on dr side. i will clearance frame with a grinder to make them work. they originaly were purchaced from ebay. seems that from head flange to back of bend on each tube could be a little shorter. some brands work perfectly.
lax54650 is offline   Reply With Quote
Old 04-30-2009, 06:21 AM   #4
lax54650
most headers state they wont work with angle plugs. you might consider a pair of 2 1/2 in rams horns do a search you will find they perform well and are relatively inexpensive. and will be less likely to leak. i thingk they can be bought for less than $200 pr.
Old 05-01-2009, 12:14 AM   #5
Why buy a ford?
Ok I found out today that one of my heads is cracked so i will be getting some heads off of a 1983 350 rebuilt with straight plugs. How much clearance did you have over your cross member? Because i know that i definately want headers but and i want short ones because long ones seem flimsy.
Old 05-01-2009, 03:57 AM   #6
Highsteel
Chasin' the Dream
Highsteel's Avatar
How about Polished Stainless Steel Ram Horn Exhaust Manifolds!
Found these at Speedway, I personally would buy these over headers all day long at $350 a pair;
They also have some plain cast ones for 59.00 a side.
Born with a Bowtie
1971 C/10 350/350 Daily Driver/project
Assumption=The mother of all -ups
Highsteel is offline   Reply With Quote
Old 05-01-2009, 06:04 PM   #7
Why buy a ford?
I love the sound of headers. i am going to have close to 350 hp when a get it finished. Do ram horns have the same type of sound, or are they like stock manifolds?
Old 05-01-2009, 06:53 PM   #8
lax54650
i believe the sound is produced by the " system" more than the headers. read this i found by using the search function. http://67-72chevytrucks.com/vboard/s...d.php?t=320079 this is exactly what i was going to do with my block huggers.
if you are looking for performance i dont think block huggers will be noticably different than rams horns. you need longer primary tubes to get better performance. i think if you are stuck on headers go with the chevelle mid length. or the rams horns i think jc whitney sells sthem for less than $200 pair. ebay chevelle headers about 135
Thread Tools
Display Modes
