Old 04-30-2009, 06:23 AM   #1
Dbrasco
Difference between 68 and 71 Frames
I have swapped my cab over from a 71 frame to a 68. I have seen where some suspension parts have different part #'s between the years. I did this to go from a lwb to a swb. I still want to keep the same look with the 71 fenders/hood. Mainly I see different part #'s in the upper/lower control arms up front. Thanks
Dbrasco is offline   Reply With Quote
Old 04-30-2009, 06:37 AM   #2
DINS 1
DINS 1's Avatar
Re: Difference between 68 and 71 Frames
The differance in parts # is going from drum brakes to disk brakes. the a arms are differant for the disk brakes. the ball joints are differant
Wade
"DURAMAX BURB" Burb on 2004 chevy 2500HD 4x4 Duramax chassis Long term project
2004 2500HD 4x4 crew cab GMC Duramax 4" lift 35's
79 RS Camaro
DINS 1 is offline   Reply With Quote
Old 04-30-2009, 07:49 AM   #3
The core support mounts are different.You`ll need to go with the frame year.
Old 04-30-2009, 08:47 AM   #4
Dbrasco
Is there a way that I can make new mounts for the core supports and then all the fenders/etc will line up? Thanks
Old 04-30-2009, 12:40 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
the 67 - 70 frame is also heavier and weaker than a 71/72 frame.
Old 04-30-2009, 01:21 PM   #6
67ChevyRedneck
67ChevyRedneck's Avatar
That I didn't know! Any more info on that Andy? New type of steel?
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 04-30-2009, 01:36 PM   #7
my67chevytruck
Under Construction
my67chevytruck's Avatar
Did you also switch the suspension. I believe you could order a '68 core support mounting hardware, and install the '71 clip on the frame ( IIRC the difference is the size of the holes etc. not a different mounting point). ppl switch out front clips all the time...
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 04-30-2009, 02:18 PM   #8
Longhorn Man
yep, new steel.
GM said the old frames were not recomended to be drilled on, but the 71/72 frames you were OK to drill into. I have a dealers letter from GMC corp. stating this.
Old 04-30-2009, 02:33 PM   #9
67ChevyRedneck
yep, new steel.
WOW! Makes you think about the peeps who have the bolt on C -notch not welded in!
Jesse James
Project "On a Dime"
Old 04-30-2009, 02:40 PM   #10
my67chevytruck
Under Construction
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 04-30-2009, 05:31 PM   #11
Dbrasco
I did transfer the front and rear suspensions over. I did have one bolt in the front that was a little off. Everything else has bolted up without a problem. As of now its a rolling chassis with the cab sitting on it. I guess as I continue on I will find out if there are any other problems. I will try ordering all new suspension for a 71. Hopefully I will not have any probelms. Thanks for all info.
Old 05-01-2009, 01:36 AM   #12
Jim_PA
How much heaveier are the 67-70's? We need to know!!!
Jim_PA is offline   Reply With Quote
Old 05-01-2009, 04:44 PM   #13
Longhorn Man
I have that book out in front of me right now, and it doesn't say how much lighter. Sorry.
Thread Tools
Display Modes
