05-02-2009, 05:58 PM | #1 |
Opinions on Frames of 67-72 Trucks
I understand that the 71-72 Truck frames are of a better steel ,,therefore stronger than the 67-70-ies..
Does this apply to all trucks 1/2 ton and 3/4 ton frames ? Are the frames better for hauling? Racing ? or adding crossmembers to the frame? Just what does the stronger frame do for you ? thought this might be a subject not covered in this way and something to add to our trivia of our trucks. In my situation (1972 frame) I have had to move the crossmember for the tranny and in doing so I have used bolts to re hook it to the frame ..Not sure if rivets are stronger than bolts ,,you tell me ..and what about doing this with the 67-70 frames ,,beings these were weaker as I was told ?? Opinions wanted.. Last edited by GOPAPA; 05-02-2009 at 05:59 PM. |
05-02-2009, 08:08 PM | #2 |
Re: Opinions on Frames of 67-72 Trucks
As far as the rivets versus bolts, I would say rivets all the way. when the rivets are swaged (for lack of a better word) in the rivet diameter expands against the sides of the hole making a tighter fit preventing movement. movement allows wear. the twisting flexing nature of a frame can work at a bolted cross member. not a highway driven truck, but a 4x4 or work truck.
"I'll Procrastinate Tomorrow" quote by LEEVON 71 K10 long fleet (sons truck) new 370hp 355, sm465 np205, 3.73's 33's 70 K20 long fleet 98 G3500 work van |
05-03-2009, 09:37 AM | #3 | |
I just want to ask if you or who ever on the forum ever heard of what I just posted about the frames on the 71-72's being stonger steel ? |
05-03-2009, 09:50 PM | #4 |
1st time hearing it a few days ago. I have no other knowledge personally, but I betcha there are others here......
05-03-2009, 11:16 PM | #5 |
It's news to me,but I've never had an issue with frames failing and I use them HARD!!! (1963,and 2 1969s) Maybe in the rusty areas it's a factor?
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme. |
05-04-2009, 12:07 AM | #6 |
20' Daredevil (Ret)
I'm not aware of any difference in the steel -- but wait 'til Andy gets back from PR, he'll probably know!
05-04-2009, 12:10 AM | #7 |
For a tranny cross member, I would think that strength should not be major major concern because most if not all of the cross members for an auto trans are just bolted in and most are bolted in on the bottom side with nothing on the top side incase you want to move the cross member with the cab still on the truck
72 Cheyenne Super 80 Silverado Blazer 2wd |
05-04-2009, 06:49 AM | #8 | |
I agree, tranny members are bolted. What I meant was just that a rivet is a solider connection in frame construction.
Thread Tools | |
Display Modes | |
