Old 05-05-2009, 08:44 PM   #1
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
should i rebuild this carb. before i install...
okay, my gmc parts truck had an edelbrock carberator on it, well, this afternoon after school i decided that i'd take it off, well took it off, and it looks pretty gunky in some spots, id say the carb is 3-4 y o......well dad said i should rebuild it before i reinstall, (inside is a lil dirt looking, and appears to have a wee bit of OIL in it)...well, im 16 on a budget.....and the trucks only been sitting 10 months, so i ask, how much a rebuild kit would be, he thought 20 bucks or so, well i looked on summit.com and a rebuild kit was close to 45 bucks....
http://store.summitracing.com/egnsea...013+115+400065
so should i rebuild the carberator before i put it back on? or should i put it on? and what're the pros and cons of this?
also, it hads a plug for an electric choke, my quadrajet 4bbl is electric choke also, but doesnt have wires going to it, edelbrock has a male plug on it on the electric choke....
sorry for the long post but thats just my current predicament now, i hope i spelled that correct haha
John
1999 Toyota Tacoma 4x4
Old 05-05-2009, 09:16 PM   #2
smoked68
smoked68's Avatar
Re: should i rebuild this carb. before i install...
The connection on the edlebrock elect. chock hooks to a 12v source. You want to use one that is only on when the ignition is on though, otherwise youll drain the batt. I'd hose it with carb cleaner and see what happens, worse case you have to take it back off and rebuild it. Good luck. Mike
1968 chevy shortbed, Dark Shadow Gray
4 bolt 383 Stroker,Weiand Super Charger, disc brakes, 9 inch, 391 gear, 20" Eagle wheels, muncie 4 speed/ Hurst shifter, 4/7 drop, Hedman midlengths, 3 inch exhaust w/ 2 chamber flows. 1966 Mustang with 306 roller, c-4, 9 inch Detroit locker rear. 1965 Fastback Mustang w/347 stroker, top loader 4spd, 9 inch detroit locker. 1966 Mustang coup, 306 roller, c4, 9 inch. 65 Cobra, 427, T6oo, 9inch, of course. First gen Hayabusa, airbox mod and running 2 exhaust cams.. Zoom Zoom Zoom
smoked68 is offline   Reply With Quote
Old 05-05-2009, 09:21 PM   #3
oldblue1968chevy
hose it, ya mean just get some carb. cleaner and squirt it down, or use the water hose??!!??!!!!
so clean it with spray carb. cleaner, put it on, and seee what happens?
and wire it to keyed power source?
John
Old 05-05-2009, 09:43 PM   #4
smoked68
smoked68's Avatar
Yep, take the carb cleaner and spray everything you can get to with it off the truck. If its still on the truck just hit all you can that way. Crank it up and see what happens. Might be ok then again my need to rebuild. Might get lucky though. I did with a junk yard cab years ago. It was a Quad. jet, and it ran great on my dads car till we sold it a year later.Nothing to lose. Good luck.
Old 05-05-2009, 09:56 PM   #5
72chevyk10
I built it
72chevyk10's Avatar
might run a shop towl where you can too. i even tore it up a little and put pieces of shop towl on the end of some nedlenose plyiers. to get in the 2ndaries. then run the carb cleaner throgh all the little holes and everything. after that "should" run prety perfect fuel wise.
note: if all the gaskets are good you really dont need a rebuild kit. just clean it out.
'72 k10 lwb 454, th400, 205, d44ft, 12b rear, 4in skyjacker, 35x12.5-15 superswampers, 4.56, blazer tank. painless wiring harness
'98 dodge 3500 12v 5sp 4x4. the truck that actually runs
Originally Posted by prostreetC-10 View Post
I think the best and cheapest performance mod is to have someone that knows what the hell they are doing perform a tuneup on said vehicle.
72chevyk10 is offline   Reply With Quote
Old 05-05-2009, 10:04 PM   #6
oldblue1968chevy
i mite replace or make a few new gaskets and pickin up some carb. cleaer tomorow after school
John
Thread Tools
Display Modes
