Old 05-06-2009, 07:28 PM   #1
jr's62
jr's62's Avatar
donors
which newer chevys can donate parts for my 62. such as front end rear end steering components, anything else that can be bolted on.
thanks
josh
jr's62 is offline   Reply With Quote
Old 05-06-2009, 07:33 PM   #2
protrash64
Resistance is Futile
protrash64's Avatar
Re: donors
73-87 will work.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 05-06-2009, 07:44 PM   #3
jr's62
jr's62's Avatar
Re: donors
is that the only years nothin newer.
Old 05-06-2009, 09:19 PM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: donors
He gave a good answer.
73-87 gives the front suspension, steering, and rearend with some mods.
In 88, lots of stuff changed. The suspension no longer interchanges, or the steering.
I'm using an 80 model as my donor.
Old 05-06-2009, 10:07 PM   #5
joe231
joe231's Avatar
Re: donors
the search feature will answer your questions
CHEVY ONLY
Old 05-06-2009, 10:18 PM   #6
jr's62
jr's62's Avatar
Re: donors
my search feature at the top of the page is not working. is this only 73-87 chevy trucks or most chevy cars and trucks within those years. i have heard that a cavalierfront end will bolt right up but i need more info than just an "i think it will". could i possibly get a short list of good donor vehicles.
thanks josh
Old 05-06-2009, 10:21 PM   #7
joe231
joe231's Avatar
Re: donors
are you using the blue theme, if so that is your problem....switch to the gray theme and all will be right again...
I would knee jerk react and think that whom ever told you cavalier doesn't have a clue...they are front wheel drive, correct???
73-87 gives you all kinds of options and they are cheap and plentiful...
BTW...I graduated from Stratford
CHEVY ONLY
Old 05-06-2009, 10:26 PM   #8
jr's62
jr's62's Avatar
Re: donors
ah front wheel drive, now i feel like an idiot for even mentioning that one. so as long as it is rear wheel driven and between 73-87 it might work. thanks for the info, off to search ebay.
thanks
josh
Old 05-06-2009, 10:30 PM   #9
joe231
joe231's Avatar
Re: donors
'73-87 1/2 ton trucks if you want 5 lug, 3/4 if you want 8 lug, and the crew cabs and suburbans up to '91.
you can get a '71-72 1/2 ton 5lug axle that is pretty much a blot in, jut a bit wider
CHEVY ONLY
Old 05-06-2009, 10:50 PM   #10
jr's62
jr's62's Avatar
Re: donors
how hard would that be to correct
Old 05-06-2009, 10:51 PM   #11
protrash64
protrash64's Avatar
Re: donors
Thanx Joe, I didnt think of the 71-72. They also work equally well but may have a couple parts that are more rare(= more $). Somewhere along the way, roughly 1980, you will start getting into metric parts, FYI.
Old 05-06-2009, 10:52 PM   #12
protrash64
protrash64's Avatar
Re: donors
You dont have to correct anything....just watch your wheel offset/backspace.
Old 05-06-2009, 10:52 PM   #13
joe231
joe231's Avatar
Re: donors
oops bolt in
how hard would what be to correct? my mis-spelling? or the axle width?
CHEVY ONLY
Old 05-06-2009, 11:35 PM   #14
jr's62
jr's62's Avatar
Re: donors
the axle width is what i was talking about
Old 05-06-2009, 11:38 PM   #15
jr's62
jr's62's Avatar
Re: donors
sorry,what does that mean.
Old 05-06-2009, 11:45 PM   #16
Captainfab
60-66 Nut
Re: donors
Wheel offset/backspacing is referring to the distance from where the wheel bolts to the axle flange, to the inside lip of the wheel. If you use a differential that is a different width, you may need to use wheels that have a particular or special backspacing.
Old 05-07-2009, 08:47 AM   #17
jr's62
jr's62's Avatar
Re: donors
would there be a problem with the steering colum out of a chevy that is between 2000-09 or any of the other interior parts such as window motor and seats. the donor could be an avelanche don't know the year but it is fairly new.
Old 05-07-2009, 09:19 AM   #18
joe231
joe231's Avatar
Re: donors
first off...are you looking for bolt in?
you can do practically anything if you have the time, money, and patients.
I don't think the column will be an easy swap, but the seats may fit....
CHEVY ONLY
Old 05-07-2009, 10:13 AM   #19
jr's62
jr's62's Avatar
Re: donors
ok thats all i needed to know.
thanks
josh
Old 05-07-2009, 12:44 PM   #20
Tx Firefighter
Re: donors
That column and it's airbag are worth enough coin to buy a nice tilt column for your truck that will basically fit without any mods.
Old 05-07-2009, 03:23 PM   #21
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
Re: donors
how much wider is the 71-72 rear axle than the 60-66
Gage
1967 C10 Shortbed Stepside
jgh64pkup is offline   Reply With Quote
Old 05-07-2009, 03:30 PM   #22
Tx Firefighter
Re: donors
1.5 inches wider.
Don't sweat it though, the front end with disc brakes is also 1.5 inches wider too.
It's a non issue really. Just compensate by running an extra 1/2 inch of backspacing on your wheel choice and all is a moot point.
Old 05-07-2009, 03:47 PM   #23
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
Re: donors
i have a 72 rear axle in my truck i was going to narrow it a couple inches on each side to make clearance for wider tires and get aftermarket axles
but i will just get a 60-66 axle
Gage
Old 05-07-2009, 05:05 PM   #24
jr's62
jr's62's Avatar
Re: donors
would the seats and window motor out the the newer avelanche work in the 62. my reasons for asking is a guy i know has a wrecked one that i might be able to get some of these parts off of for maybe cheaper than i could somewhere else.
Old 05-07-2009, 11:07 PM   #25
Captainfab
60-66 Nut
Re: donors
I will add that you can do most anything you want if you have the tools and the skills to use them. If you're looking for easy power windows, then I don't think those would work. The seats on the otherhand may not bee too hard to mount. There are currently a couple of threads on here regarding newer seats in these trucks.
Thread Tools
Display Modes
