Old 05-08-2009, 09:03 PM   #1
exmonkeypunk
Barrito Loco Diablo
exmonkeypunk's Avatar
lowering and drive shaft question
If i'm pulling a couple rear leafs on my 3/4 ton should i have to worry about any driveshaft issues? It's stock in the rear and roughly 2 to 3 lower in the front.
exmonkeypunk is offline   Reply With Quote
Old 05-09-2009, 01:29 PM   #2
exmonkeypunk
Barrito Loco Diablo
Re: lowering and drive shaft question
i've been told that when i lower the rear any i cause the drive shaft to bind at the u joints. I wouldn't think lowering it a few inches should cause any issues. Any input?
Old 05-11-2009, 09:58 AM   #3
6772owner
Gearhead
6772owner's Avatar
My only input from my experience is that you will want to keep an eye on the pinion angle change once its at the new lowered height. If there is too much angle (will be pointing down not level or up) you can get pinion angle shims to correct the problem. You can also measure the current angle with an pinion angle finder and just make sure its close to that when lowered (might not need shims)
Hope this helps....
2002 Saturn SL2, My D/D
2019 Ford Fusion SE, Ecoboost - Wife's D/D
1993 Camaro Z28, A4, CAI, Cat-Back Exhaust
Project C10 (my 72' C10 w/96' LT1, 700R4, bagged F&R, 18's (for now), Short/Fleet) -- SOLD!
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=313644
6772owner is offline   Reply With Quote
Old 05-11-2009, 04:25 PM   #4
mycool72
mycool72's Avatar
It shouldn't be an issue with a small drop.
mycool72 is offline   Reply With Quote
Old 05-11-2009, 06:38 PM   #5
exmonkeypunk
Barrito Loco Diablo
Hope this helps....
My thoughts were also that there shouldn't be an issue with a small drop like this. I suppose i should pick up a pinion angle finder before i go doing anything. Personally, i like the rake. It's the Lady that doesn't like it. Then again, i haven't found a woman that ever did like a raked vehicle. Must be a dude thing, or a hill rod dude thing. I like it.
Thread Tools
Display Modes
