05-15-2009, 12:57 AM | #1 |
seat belts
hi i was wondering what seat belts to use. i have a 1963 w. mid 1990's suburan bucket seats, any suggestions would be great
05-15-2009, 05:55 AM | #2 |
Re: seat belts
That makes 2 of us. I orignally built my truck before I had kids so I took them out and tossed them but now its time to put belts in it so the kids can go along.
05-15-2009, 07:16 AM | #3 |
Registerd User
Re: seat belts
I got the ones from LMC. They bolt to the floor and just stick threw where ever you want them to .
05-15-2009, 11:01 AM | #4 |
Re: seat belts
I got some at a swap meet Drilled two holes for eah set and Like Jason said "bolt them up "
You coul also try using the belts that were on your "mid 1990's" 'burban.
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
05-15-2009, 12:48 PM | #5 |
Re: seat belts
in the 01-06 chevy trucks the belt is biult into the seat and i think the latch just bolts to the floor,for me this is the easiest becuase i do not have to cut any metal.
05-15-2009, 01:05 PM | #6 |
60-66 Nut
Re: seat belts
When adding seat belts to a vehicle that wasn't originally equipped, it is a good idea to add a piece of steel reinforcement on the bottom side of the floor where the seat belt bolt goes thru the floor. Similar to what the factory did. It doesn't take a big piece, just something to give more surface area so the bolts don't just pull thru the floor in the event of a crash
05-15-2009, 02:27 PM | #7 | |
Recreational Grease Monkey
Re: seat belts
Robert Last edited by Revin68; 05-15-2009 at 02:28 PM. |
05-15-2009, 08:42 PM | #8 |
Re: seat belts
mine ain't got seat belts, and I'm sure as heck not gonna add them. hate'em
05-15-2009, 11:24 PM | #9 |
...just another truck junkie..
Re: seat belts
I had that attitude once.... and then I saw what happened when my sister ate the steering wheel of a '76 Caprice after a semi ran a stop sign and pulled out in front of her. She survived, but her face was busted up bad, lost 4 teeth and had over 100 stitches inside her mouth. I've worn seat belts ever since and so has she.
Mike "Bear" Shea |
05-16-2009, 07:40 AM | #10 |
Re: seat belts
After many years of racing I feel uncomfortable with out a seat belt on.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
05-16-2009, 11:32 AM | #11 |
Re: seat belts
I carry my kids in my truck, I won't take chances. Was hit head on by a drunk and he was in a half ton PU.... Belts saved my whole family's life. I too feel weird w/o them.
Also, the problem I have with OEM salvage belts is limited color choice. A good upholstery shop can replace the belt material with new nylon in a variety of colors. Robert |
05-16-2009, 04:34 PM | #12 |
Re: seat belts
Here are a couple sites I was looking at for belts. I still wonder how diff. it is to add a 3 point setup?
http://www.trubelt.com/products/details/id/20 http://gotbelts.com/index.html
66' Chevy SWB:350ci-th350,frt. disc brakes, pwr steering, 5-lug waltshow.com/Chevy |
05-16-2009, 05:25 PM | #13 | |
1 thing at a time is progress.
Re: seat belts
Here is a pic of the way I bolted my seats down with builtin seat belts in the seats. I don't know the name of them. The are used in unistrut for commercial electrical and plumbing to hold pipes up in the ceiling. Precut and already have the hole in them.
Alan
Philippians 2:14-16 |
Thread Tools | |
Display Modes | |
