05-16-2009, 09:58 AM | #1 |
Rebuilding rocker boxes stock vs custom?
My 71 Blazer is going to need replacing stock rocker boxes and some floorboard in the corners or custom fab work to make it strong enough to keep the top off. Anyone have a opinon on which way to go? I can do the work each way. Any pics of custom support work?
] : - 71' burb,5.3,4wd 02' f350.7.3 00' F250-powerstroke 00' Roadstar 84' Eagle model 10 72' GMC 18' camery 12' ZX14R- |
05-16-2009, 10:46 AM | #2 |
SKINNY TIRES RULE!
Re: Rebuilding rocker boxes stock vs custom?
I figure GM had a team of engineers on the project, so they probably devised something better than I could so I'd stick with stock.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
05-16-2009, 05:04 PM | #3 |
What exactly is the purpose of the rocker boxes? Is it to stiffen up the body?
05-16-2009, 07:26 PM | #4 |
SKINNY TIRES RULE!
There was a thread about the proper name and it was determined to be "torsion box". I've heard them called both. They are the structural support of the body when the top is off.
05-16-2009, 11:09 PM | #5 |
Wow. That was quite a thread. Thanks for the tip and I will now be calling them torsion boxes. Great info to have.
05-17-2009, 12:05 AM | #6 |
SKINNY TIRES RULE!
ditto!
05-17-2009, 09:35 AM | #7 |
GEARHEAD
I think they devised something cheap, simple and just meets the requirements. There are always better, stronger ways to do things. If you look at what racers, off-roaders, etc. do with their stuff, you realize just how much some of what the factory did was inadequate for anything beyond driving down the highway. Considering that these vehicles are well past their expected usable lifetimes, re-inforcement in structural areas would not be a bad thing. Stress cracking, corrosion, poorly done previous repairs, and just plain wear and tear to crossmember rivets, bolts, suspension components, and the things that happen when someone takes it out for a nice romp in the field will weaken areas not seen. Putting stock replacement stuff on is good, but by no means should be considered the only or best solution.
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 Long Fleet C/10 72 Jimmy 4x4 (Junkyard Jimmy) HG's Plow Truck '78 K35 Dually Bigass Farm Truck HG's thread of miscellaneous stuff |
05-17-2009, 11:47 AM | #8 |
SKINNY TIRES RULE!
Since factory replacements only recently became available, I've seen a few creative solutions in the past. This is the only one I have pictures of.
05-19-2009, 10:48 AM | #9 |
I am very interested in that picture....too bad that is the only pic you have.
I might end up doing something like that later down the road? |
Thread Tools | |
Display Modes | |
