Old 05-19-2009, 03:49 PM   #1
coggonobrien
What TKO 600 kit?
I'm sticking a big block in my 2wd c20 and just wondering what tremec tko 600 kit would be the best fit? I have a high hump cab. By kit I mean it will include everything (clutch, bell housing, possibly a generic crossmember).
Thanks!
David
coggonobrien is offline   Reply With Quote
Old 05-19-2009, 04:32 PM   #2
smoked68
smoked68's Avatar
Re: What TKO 600 kit?
You'll want the premier I think they call it. It has everything. I'm getting the middle package and its a little over 2800.00. Have fun.
1968 chevy shortbed, Dark Shadow Gray
4 bolt 383 Stroker,Weiand Super Charger, disc brakes, 9 inch, 391 gear, 20" Eagle wheels, muncie 4 speed/ Hurst shifter, 4/7 drop, Hedman midlengths, 3 inch exhaust w/ 2 chamber flows. 1966 Mustang with 306 roller, c-4, 9 inch Detroit locker rear. 1965 Fastback Mustang w/347 stroker, top loader 4spd, 9 inch detroit locker. 1966 Mustang coup, 306 roller, c4, 9 inch. 65 Cobra, 427, T6oo, 9inch, of course. First gen Hayabusa, airbox mod and running 2 exhaust cams.. Zoom Zoom Zoom
smoked68 is offline   Reply With Quote
Old 05-19-2009, 04:40 PM   #3
69GMCLonghorn
69GMCLonghorn's Avatar
Hey, keep us posted on the outcome. I have a '69 with an NP435. If I don't lose my job in the near future, I'd like to upgrade to something with an O/D.
69GMCLonghorn is offline   Reply With Quote
Old 05-19-2009, 04:44 PM   #4
coggonobrien
are you buying direct from tremec?
Old 05-19-2009, 05:30 PM   #5
chevy_mike
Never Ending Projects
chevy_mike's Avatar
I had put a TKO 600 into my '69 Camaro and LOVED it. I originally bought a TKO (pre 500-600 models) and by the time I got to the point of installing it, the 500-600 series came out. I sold my TKO and bought a 600, mainly due to the higher torque handling and I liked the gear ratio spacing better. It was an awesome tranny and if I had the funds, I would do another one in my truck.
As for what/where, I can't recommend Classic Motorsports Group enough. Bought my 600 from them and they had a ton of great info/tricks. It was still kind of new putting in the Tremecs at the time.
They have a kit for 60-72 Chevy trucks, based on what you already have installed and you would do well to get a full conversion kit from them.
http://www.classicchevy5speed.com/GM...it-Select.aspx
The #1 think about these TKO's they are VERY sensitive to input shaft runout. Make sure you setup your bellhousing within specs or you will cause a lot of problems, like hard shifting, wear and parts failure. Looking at their current kit, they have a new bellhousing setup that is really nice compared to what was available 5 years back.
Good luck and keep us updated.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 05-19-2009, 07:11 PM   #6
BossHogg69
motor exploder
BossHogg69's Avatar
I got my TKO 500 from www.standardtransmission.com, they were VERY helpful and got me everything I needed to install my tranny, except the bellhousing, which I used a fairly common Muncie '621' housing that got on eBay. I used my existing auto trans crossmember (turbo 400) and just moved it up a few inches.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 05-20-2009, 09:03 AM   #7
smoknbarrels
Registered Mail
smoknbarrels's Avatar
The mid shifter option seems like a waste, you can order these trannys with the shifter mounted in any position you want. and they are easy to change, I ordered mine all the way back, and all you do is unbolt the cover, spin it 180 degrees and its in all the way front position. really awesome system for guys doing mods or wanting to throw it in a different car.
kit looks cool, I like the light weight k-member.
are you using a ford 9? it may throw off your drive shaft measurement..
smoknbarrels is offline   Reply With Quote
Old 05-21-2009, 06:08 AM   #8
coggonobrien
yea i am planning on building a ford 9" when the transmission goes in, i'm assuming the driveshaft will be a custom length, just gotta measure it.
Old 05-21-2009, 06:16 AM   #9
coggonobrien
so if i'm reading write online would i be able to use the bell housing on my stock 4 spd with the tremec?
Old 05-21-2009, 07:21 AM   #10
Jim_PA
Yes - Are you building some serious horsepower? Have you checked your gearing and tire size vs the 1st gear ratio of the 500 and 600?
I'm hoping to do one of these in the next year or so.
Jim_PA is offline   Reply With Quote
Old 05-21-2009, 07:48 AM   #11
coggonobrien
I haven't started looking into the final drive ratio with first gear yet. I've got a 396 that will be bored to either 402 or 427. plan is to fuel inject it and gun for 500hp at the crank. rear tire will be about 29 tall so I was intending to use 4.10 gears for a good highway rpm. Would this render 1st gear useless?
Old 05-21-2009, 10:08 AM   #12
Jim_PA
I'm not sure, you'd have to do the shift point math... I just know that the 500 has a 3.xx 1st, while the 600 has 1st in the 2.xx range....
4.10's with a 29" tire might make first a little high with the 600.
Old 05-21-2009, 11:02 AM   #13
BossHogg69
motor exploder
BossHogg69's Avatar
TKO500 is 3.27 first gear, TKO600 is 2.87.
I personally really like my TKO500/3.73 rear gear combo, the 2.87 may be nice with a 4.11???
shift point math....
http://www.5speedtransmissions.com/startlineratio.html
http://www.5speedtransmissions.com/distancecalc.html
http://www.5speedtransmissions.com/gear_calculator.html
Adam
Old 05-21-2009, 12:37 PM   #14
Jim_PA
I was thinking the same thing until I saw he had 29" tires. What size are yours?
Old 05-21-2009, 03:43 PM   #15
BossHogg69
motor exploder
BossHogg69's Avatar
mine are 275/60/15 right now, nominal height is 28", but they're closer to to 27" tall with 35psi of air in them on the truck. After I swap my 6 lug drums to discs, I plan on a set of 20" wheels, but will still keep the tire height to around 27".
Adam
Thread Tools
Display Modes
