Old 05-19-2009, 11:50 PM   #1
84socal
trans rebuild ?s
ok i burnt up the trans its a th400 and i am gonna have it rebuilt
1st question is should i have a shift kit put in it as well
since im primarily gonna use it to tow with will it help
2nd is what size trans cooler should i be using
any specific one i should use or stay away from or one of the universal ones from the local vatozone work ??
84socal is offline   Reply With Quote
Old 05-20-2009, 01:23 AM   #2
Bus Ted Knuckle
Son of a gun
Bus Ted Knuckle's Avatar
Re: trans rebuild ?s
If you have to rebuild it anyway, might as well throw in a shift kit...I buy the more expensive trans coolers that orievancezone sells, they give me good service.
BEATERS ARE NEATER
Bus Ted Knuckle is offline   Reply With Quote
Old 05-20-2009, 05:45 AM   #3
z400rider8787
it will help with towing for sure. Im ASE certified in trannys and i can tell you a shift kit will prolong the life of your tranny by a lot. the less time between shifts the less friction, wear, and heat. as for tranny coolers they are all pretty much the same, the biggest you can get the better, the main cause of tranny failure is heat. the extra price of a large tranny cooler with a fan is much less than a rebuild
z400rider8787 is offline   Reply With Quote
Old 05-20-2009, 08:29 AM   #4
WorkinLonghorn
WorkinLonghorn's Avatar
I'll third that,about the shift kit. Those TH-400s in a Caddy,Olds 98 or other land-barge were designed so you never even noticed a shift so the shifts were very soft (long). For a truck,and especially for towing get a kit but not a race kit.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
Old 05-20-2009, 05:22 PM   #5
84socal
ok cool thanx guys thats the help i was lookin for
Old 05-20-2009, 05:27 PM   #6
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Get a shift kit designed for towing.I would use one in a truck even if I weren't using it to tow a lot.I would definitely run the biggest cooler available and If they offer a tranny filter(external) I would seriously consider one.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 05-20-2009, 06:33 PM   #7
So.Cal.Super
It'll Buff Out!
So.Cal.Super's Avatar
Another vote for the shift kit! And I like Tru cool LPD (low pressure drop) coolers myself. its what my two friends shops install and it is what I installed on my truck. this will help explain it better.
http://www.performancetransparts.com...ction=VIEWCATS
edit. They make different sizes,not just "long" you just have to google them.
"Instructions are just another mans opinion"
Become a Supporting Member
Man Card Rules
http://67-72chevytrucks.com/vboard/s...d.php?t=634550
72 Chevy Cheyenne Super 400 LWB
So.Cal.Super is offline   Reply With Quote
Thread Tools
Display Modes
