Old 05-19-2009, 11:59 PM   #1
Outlaw_71
Outlaw_71's Avatar
Trying to figure out what chassis my truck is on.
Truck is on a 4wd chassis. I believe the t-case is np203 since the shift pattern is-
(front)
low loc
low
nuetral
high
high loc
(seat)
and this is on the knob as well.
It has a 350 sbc. I'm not sure whether the engine is from the truck the cab and bed came from or the truck the chassis and trans/transfer case came from. The reason i know it is not the stock chassis is because the vin on the glovebox says it was an original 2wd truck and the t-case shifter was brought up through a cut through the floor boards. I guess my question is what years chevy fullsizes had NP203's with this shift pattern and how to determine what year the chassis is. My mechanic geustimated about a '75 silverado. What can i check to identify this?
EDIT- If it helps it also has locking hubs and i think my mechanic said it has a 350 trans. It also has heavy leaf packs. I'll count them tomorrow.
VIN on glovebox says 1972, previous owner says 1971 C10 4x4 Convert. 7" of lift. New 33" Cepek Mud Country's. Thanks to our Vets past and present
Outlaw_71 is offline   Reply With Quote
Old 05-20-2009, 01:46 AM   #2
Dooley
Dooley's Avatar
Re: Trying to figure out what chassis my truck is on.
GM used the 203 transfer case 1973-79 in light truck line with automatic transmissions. These units did not have manual locking hubs.
Dooley is offline   Reply With Quote
Old 05-20-2009, 02:00 AM   #3
Mudder
Mudder's Avatar
Chassis. 67-72, rear shocks mount from the same side of the rear axle. 73- to ??? mounts one in front and the other in the rear of the axle.
Mudder is offline   Reply With Quote
Old 05-20-2009, 11:49 AM   #4
Outlaw_71
Outlaw_71's Avatar
Mudder you've got the answer. It is 73 up. Is there anyway to figure out the exact year. Can you find the vin or some sort of id number on a chassis?
Old 05-20-2009, 11:59 AM   #5
Outlaw_71
Outlaw_71's Avatar
Here's a pic of my shift knob. Maybe this can help identify it? I just added the boot.
Old 05-20-2009, 04:21 PM   #6
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
Well mine is like that and it is an 81.
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 05-20-2009, 09:37 PM   #7
Outlaw_71
Outlaw_71's Avatar
Cool man. Looks like i'm going to have to do a little searching to find a truck with the same chassis and shifter setup as mine. Does anyone know how to identify the engine? I don't know if it is from the chassis truck, cab and bed truck or neither.
Old 05-20-2009, 11:47 PM   #8
Captainfab
60-66 Nut
The frame should have the VIN stamped on the top flange on the drivers side close to the motor mount. The engine will also have a partial VIN along with the build code stamped on a pad in front of the passenger side head. It will be behind the alternator if yours is on that side. Probably have to scrape off dirt, grease and paint to see it.
Old 05-20-2009, 11:51 PM   #9
Outlaw_71
Outlaw_71's Avatar
Sweet man. I'll check that out. Thank you.
Old 05-21-2009, 12:17 AM   #10
OrrieG
OrrieG's Avatar
Originally Posted by Dooley View Post
GM used ... transmissions. These units did not have manual locking hubs.
Unless a part time kit with hubs was added at some time.
OrrieG is offline   Reply With Quote
Old 05-21-2009, 12:53 PM   #11
Yeah,like about all of them.That full-time was a bad mistake.No secret,either.
Old 05-22-2009, 10:59 AM   #12
Outlaw_71
Outlaw_71's Avatar
What are yall talking about full time 4wd for? Maybe i don't understand hubs but one of my buddys whos a 4wd tech was telling me that my 4wd wouldn't engage unless I locked my hubs and then put it in 4 wheel. I think the hubs were added but what makes em work? what exactly do they do? Sorry if i'm noobing out on you guys but this is my first truck. I've not had a lifted or 4wd truck before. Alot different than my old monte carlo ss.
EDIT- Maybe yall were saying you think this was a full time 4wd chassis originally and the hubs were added so that the driver could decide when it engages?
Old 05-22-2009, 08:24 PM   #13
Damien
Damien's Avatar
The '73-87 trucks used different steering components. Here is a link from LMC that will help narrow it down. http://www.lmctruck.com/icatalog/cc/full.aspx?Page=139
I can still count my vehicles on two... wait three hands.
Damien is offline   Reply With Quote
Thread Tools
Display Modes
