Old 05-24-2009, 09:41 AM   #1
Field and Son
Field and Son's Avatar
Crew Cab and Suburban Frames
Does anyone know if a 1976 era crew cab frame is the same as a suburban frame??
Field and Son is offline   Reply With Quote
Old 05-24-2009, 11:35 AM   #2
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
Re: Crew Cab and Suburban Frames
not the same.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 05-24-2009, 05:05 PM   #3
pig rig
pig rig's Avatar
the crew cabs wheel base is about 14' and the subs are about the same as a std cab
my sports car rolls on six wheels only because I'm to fat to get in and out of new corvette
http://hubgarage.s3.amazonaws.com/ph...ped_detail.JPG
pig rig is offline   Reply With Quote
Old 05-25-2009, 07:21 AM   #4
ghettoluxury
ghettoluxury's Avatar
only the same to the back cab mounts
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 05-25-2009, 09:01 AM   #5
Dooley
Dooley's Avatar
The Suburban has a 129.5" and the crewcab has a 164.5 wheelbase.
Dooley is offline   Reply With Quote
Old 05-25-2009, 12:34 PM   #6
Robertw
so this wouldnt work for a crew cab short bed build just asking
Robertw is offline   Reply With Quote
Old 05-25-2009, 01:39 PM   #7
smashingchuck
nope.
78 Build Thread
4Runner Build
Old 05-25-2009, 10:00 PM   #8
Robertw
Originally Posted by smashingchuck View Post
nope.
didnt think so
Old 05-26-2009, 12:51 PM   #9
ghettoluxury
only if you use the front part of the burb frame and mate it to the back half of a shortbed frame, did this fo a friend a couple months ago
Old 07-15-2009, 04:51 PM   #10
Tow Me
Glen
Tow Me's Avatar
My dad and I just got done welding together a Suburban frame and a short bed truck frame. We measured it out perfectly so that we cut the frame in a straight section of the frame and were able to mount the rear cab mounts in the right place. All the holes line up even for the gas tank. Its like the factory short bed crew cab frame Chevy never made. I don't think it matters but mine is a 1/2 ton now. The old frame crew cab long bed frame was 3/4 ton.
I have never heard of anyone doing this, but my dad came up with the idea after seeing a guy that built crew cab rock crawler with a flat bed... all on a Suburban frame.
Tow Me is offline   Reply With Quote
Old 10-05-2009, 12:49 PM   #11
sailed2japan
Jonny
sailed2japan's Avatar
That can be done, but you'll have a bed about 3-4' or so long.
1966 C30, Cummins, stacks, and a flat bed in progress...
"Honor.....simply put,
A veteran - whether active duty, retired, national guard or reserve is someone who, at one time in his life, wrote a blank check made payable to 'The United States of America', for an amount of 'up to and including his life.' That is Honor, and there are way too many people in this country who no longer understand it."
-AEC Hundley USNR
sailed2japan is offline   Reply With Quote
Old 10-05-2009, 01:21 PM   #12
Tow Me
Glen
Tow Me's Avatar
Our frame does not require a 3-4' long bed. Its a standard short bed now. We measured for that exact reason. Its what a CCSB frame would be from the factory.
Glen Simpson
Severed Ties - Oregon
Roseburg, Oregon
  • 1983 Chevrolet C10 - Ginger
    Photos
Past Trucks
Old 10-05-2009, 05:47 PM   #13
Storm Chaser
Storm Chaser's Avatar
There are a few crew cab short beds done by members of this site. Rick (TooManyToys) did one with a stepside bed.
1988 R2500 Crew Cab
Immediate plans- get it running!
Future plans-
Rear disc swap & Hydroboost
Dually conversion with shackle flip-n-switch
4x4 conversion with 52" springs
Maybe some new body panels
Who needs a car when they make crew cab trucks?
Storm Chaser is offline   Reply With Quote
Old 10-17-2009, 01:04 PM   #14
sailed2japan
Jonny
Yeah I was talking about putting a crew cab on a burb frame w/o mods. sorry I guess that was placed oddly.
-AEC Hundley USNR
Old 10-18-2009, 10:18 PM   #15
Storm Chaser
Oh, I see. Well, as far as the cab goes, the front-most body mounts on the cab will go right to the same on the frame. This will locate your cab where it needs to be on the frame (naturally, the core support will be correct also. I know this much to be right, as I cut up a burb right next to my crew cab and measured it out for an idea I abandoned
What I don't know (cuz I didn't measure) is if the middle mounts on the cab line up on the frame right, and I'm pretty sure that the rear-most cab mounts will NOT line up with anything on the burb frame. It wouldn't be difficult to fab up some cab mount perches, and the front ones will locate the cab for you, so at least you have that.
Burb rear doors are the same as crew cabs, so you shouldn't have much trouble with the back tires getting into the cab, unless your tires are monstrous.
1988 R2500 Crew Cab
Future plans-
Old 10-19-2009, 12:21 AM   #16
ghettoluxury
yes the middle mounts line up
Old 10-19-2009, 02:23 AM   #17
sailed2japan
Jonny
But the rears don't?
So just a set of custom rear mounts away from having a funky crew cab rock crawlin' off road riggamaroo?
-AEC Hundley USNR
Old 10-20-2009, 12:02 AM   #18
Storm Chaser
Yea, the rear most cab mounts on the crew cab are just like the rear mounts on a standard cab- they are more inboard than the others, sitting on a crossmember. On a Suburban, the 'cab' doesn't end there (so to speak), and if I remember correctly, what would be the last set of mounts on a crew cab are still on the outboard side of the Burb frame (I may be wrong, so if anyone knows, let us know). If I'm not mistaken though, you should be able to take that crossmember from a truck frame and easily install it to the Burb frame for your rear mounts.
What are your plans for the bed?
1988 R2500 Crew Cab
Future plans-
Old 10-20-2009, 12:03 AM   #19
Storm Chaser
Ghetto, are those middle perches the correct height also?
1988 R2500 Crew Cab
Future plans-
Old 10-20-2009, 05:44 AM   #20
ghettoluxury
Correct and yes the middle mounts are the correct height the ccsb we built we ised a 1/2 ton burb till about 6 inches behind the middle mount and a 1/2 ton shortbed from there out.
Old 10-24-2009, 04:24 AM   #21
sailed2japan
Jonny
does anyone know the difference between a 1/2 and 3/4 ton 'burb frame, if there is one?
-AEC Hundley USNR
Old 10-24-2009, 03:16 PM   #22
ghettoluxury
frames are the same height
Old 10-25-2009, 02:24 AM   #23
sailed2japan
Jonny
So the only difference between a 3/4 ton burb and a 1/2 ton is running gear? i guess they didn't plan on burbs carrying too much weight.
-AEC Hundley USNR
Old 10-25-2009, 06:00 PM   #24
1774btcrew
1774btcrew's Avatar
Is there a reason you are so set on the Suburban frame for under a crew cab? If you already have a crew cab with a frame under it the easiest way is to just shorten the frame. I did mine and it came out excellent! it was within 1/16" of an inch from being exact from side to side. I put all half ton suspension under it. Mine has a 4bt with a 4L80 transmission and a Compushift controller with 3.73 rear gears. I love the truck!
1774btcrew is offline   Reply With Quote
Old 10-25-2009, 06:34 PM   #25
sailed2japan
Jonny
I'm not set on anythin I was just cntemplating different things and wondered if the 3/4 ton burbs had a heavier frame like 3/4 and 1 ton truck do. How much did you take out of the frame to make yours? I'd actually much rather like to have a 3/4 ton frame as I plan on running a 6bt of some sort. Do you have a build tread on your truck?
-AEC Hundley USNR
Thread Tools
Display Modes
