Old 05-24-2009, 04:25 PM   #1
420am
420am's Avatar
Heater valve on inner fender.. can I eliminate it?
I'm missing most of my AC stuff. In time I'll be going the AC delete route and cleaning up my firewall. So, I'm not planning on putting AC back in my truck (if I decide to later there's always Vintage Air). I believe after reading this:
Originally Posted by Longhorn Man View Post
That valve is only actuated when the A/C is turned on.
That I can just run the hose back bypassing this valve with no effect. I just want my heat to still work.
Thanks for the preliminary answer Longhorn Man.. just making sure I understand things correctly.
1972 Long Bed Cheyenne
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=285282
Waste my bandwidth and listen to some great tunes >> http://www.radioxenu.com (Live Shows with yours truly every Friday)
420am is offline   Reply With Quote
Old 05-24-2009, 04:49 PM   #2
leddzepp
Moderator
leddzepp's Avatar
Re: Heater valve on inner fender.. can I eliminate it?
That valve shuts off hot antifreeze from going thru the heater core when the A/C is on. Since the heater core and A/C evaporator core sit right next to each other, this keeps the heater core from heating up and cancelling out the A/C.
To answer your question, yes you can eliminate it if you are not using A/C. Just make sure that you cap off the vacuum source to it.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 05-24-2009, 05:48 PM   #3
420am
420am's Avatar
Thanks man.
Old 05-24-2009, 05:56 PM   #4
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
thanx for the info but I have the same desease but plan on fixing my A/C what are you removing Mine has been raped of all the the lines and condesers
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Thread Tools
Display Modes
