Old 05-28-2009, 05:21 PM   #1
rex855
Front coil removal w/ no engine weight
Hey Guys,
I have a front cross member still attached to a cut front portion of frame and I need to disassemble it but there is tension on the coils. How do I go about removing the coil with out any engine weight to keep the coils compressed while removing the spindle nuts?? Could i just take a sawzall to the coil and hope it all stays in the spring pocket??? any suggestion would be great.
Thanks in advance,
Rex
rex855 is offline   Reply With Quote
Old 05-28-2009, 05:59 PM   #2
Tri5Nerd
Tripple Five Fanatic
Tri5Nerd's Avatar
Re: Front coil removal w/ no engine weight
Originally Posted by rex855 View Post
Hey Guys,
Thanks in advance,
Rex
If you have a Kragens near you go rent a spring compressor, DO NOT get the one from AutoZone, I'm still recovering from a busted finger because of that one.
Tri5
Tri5Nerd is offline   Reply With Quote
Old 05-28-2009, 09:06 PM   #3
XXL
Seņor Member
XXL's Avatar
Sawzall is going to wear you out trying to cut spring steel. If you've got a small cutoff wheel or grinder, you can just brute force your way through one of the links until it gives under its own weight. Or... tie the coil spring to the frame with a tiedown or similar so that it doesn't fly out at you when you pop the ball joint as usual.
XXL is offline   Reply With Quote
Old 05-29-2009, 12:13 AM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
If your not going to reuse the coil, then torch it. If you are then XXL has the right approach.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 06-01-2009, 10:08 PM   #5
AusTx68
AusTx68's Avatar
So I had the same question and came across this posting. Following XXL's advice, I used a small cutting wheel to cut through the links.
I started with my front suspesion upside down on the floor of my garage. The upside position was purely by accident but ended up working for me.
Once my compressor was ready I straddled the front cross member so I would be protected by the lower control arm. I then reached around and positioned the cutting wheel between the shock and spring. I left the shock in place to act as another barrier should the spring fly out.
Getting thru the first half of the spring is pretty easy. Towards the end I started moving the wheel around the remaining metal from top to bottom making sure to keep my hands on the outside of the spring. With a little less than 1/4 inch remaining, POP!!. Boy that caught me be suprise. When it lets go you get a sense of the pressure you're dealing with.
I did the same to the other side. Except once I got down to 1/4 inch I stopped and tried hitting it with a hammer to see if I could make it pop. No deal. I had to keep cutting until the link broke on its own. This time I knew it was coming but it's like playing with a mouse trap. You know it's coming then POP!
Thanks guys for the idea! Now I can disassemble, sandblast and paint it with POR15.
'68 C-10 SWB 383 Stroker (Sold 3/2/2013)
'87 R2500 LWB 454 TBI converted to Carb
AusTx68 is offline   Reply With Quote
Old 06-10-2009, 11:40 AM   #6
rex855
Thnx guys for the great advice. I'm gonna try it this weekend. Been busy with work but now is the time get this thing done.
Old 06-16-2009, 06:46 AM   #7
63sbssbbw
UCA63
63sbssbbw's Avatar
I used 2 pieces of angle iron about 2 ft long,drilled a hole in each end of both,then used 2 lenghts of 5/8 ready rod(about 2 1/2 ft long,they need to span the UNsprung distance and still have thread engagement)
Undid the castle nuts enough to break loose the BJ
Clamp upper and lower A arms between angle iron and ready rod,it will basically look like a square framework around upper and lower,(double nut bottom side to prevent rod from turning)tighten framework enough to remove castle nut,then unthread nuts on RR moving from side to side to keep it even to release spring in a controlled manner.
I will also use this bit of redneck tech to reinstall(hence making sure the rods are long enough) as no motor or trans will be present when I reinstall
I thought it worked good enough to share and I will be keeping these pieces for future projects and my buddies to use.
Thanks ,T
member#7816
"63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt
'61 GMC in progress
'63 GMC to use for parts
'90 Chevy Ext cab sbfs 5.7l (current d d)
63sbssbbw is offline   Reply With Quote
Thread Tools
Display Modes
