Old 06-03-2009, 04:31 PM   #1
Reno's71
Gear vendor overdrive? Worth it?
So I have 4.56 gears with 35's. If I there was such a thing as say a 4.20 gear ratio, Id be fine. I reach about 3k RPM @ 65 MPH There is one other way to fix it which would be 38's. But that is overkill, to me.
So then their is Gear vendors Overdrive. They will split the gearing to be like a 6-Speed. With somthing like a .80 overdrive. Cruising @ 70MPH will no longer be a hassle. Although, problem is the kit is about 3 thousand dollars. Its iether do the GV OD and spend less on a daily, or just have a nice daily. Im thinking get a POS daily so I can enjoy my truck some more.
What you think?
-Reno
Reno's71 is offline   Reply With Quote
Old 06-03-2009, 05:20 PM   #2
Yukon Jack
Post Whore
Yukon Jack's Avatar
Re: Gear vendor overdrive? Worth it?
If you're looking to do it to get better mpg and save money, I'd say don't bother. To save $3,000 in gas would take a long, long time. These 4x4's are bricks anyway and I doubt the gas savings would add up to much anyway.
Is this for your 71? What engine and tranny do you currently have? Assuming this is for your 71, I see it is a short bed truck. Gonna make for a fairly short rear axle driveshaft. Don't know if that will cause you any problems, but something to keep in mind.
If you are just wanting to do it so you can drive 70 mph and money isn't an issue, than that makes the decision pretty easy.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 06-04-2009, 01:13 AM   #3
Reno's71
Honestly, If I wanted good MPG Id get a Civic. I have a 305 for now, and auto trans. I did think about the SWB and talked with someone on the phone from GV OD. He said that worse case senario, Id need a 2 piece setup. Admit it, driving at 55 isnt so fun. I could drive faster, just dont want to blow my motor yet. A built 350 is in store in about a year. Untill then, the 305 needs to last. I think I'll bite the bullet and just do it. A manual 6 speed swap would be more expensive...
Old 06-04-2009, 07:11 AM   #4
Just drive 70.You`re just used to o/d.I`ve been driving these trucks for years at 3,000+ rpm and never thought a thing about it.I did wonder why late-models with louder exhaust had such a droan sound compared to my sweet note.I`ve driven a camper hauling truck with 4.10s all over the country.That thing loved 75-80 mph.
You have about 4.10 gears now with those 35s.
For years I drove a`71 K/20 with 4.57s & 37s up and down the interstate to work.
I think the Gear Vendors units are the greatest thing since sliced bread.I really want one in my 2wd shortbed w/M-22 and 3.42s.But,dayum!,they`re so expensive.it`s a rich man`s novelty.I can build a couple motors for what they cost.If the cost is no big deal,then buying alot of gas or new motors won`t be a problem,either.It all comes down to riding comfort,in my mind.Comfort is in your mind,so either yoiu can deal with (and I enjoy it) higher revs or spend a few grand to run a bit smoother and quiter,as well as go a bit farther on a tank and hope your engine lasts a bit longer.
Old 06-04-2009, 04:28 PM   #5
Reno's71
My engine is just fine for now. I drive about 20 or so miles on the highway twice a day. 3K RPM isnt a problem. Id be rest assured If I knew it wouldnt cause further stress to my motor.
Or, what if I do build a motor that is more designed for higher RPMs.. Like some lifters, different cam, and some heads. I have the 4.56 to take care of the low end. Maybe just build a cammed motor, It will like the RPMs a little better. Yes, no? That would be about as much as the overdrive, plus its not the 305
Old 06-04-2009, 11:10 PM   #6
Yukon Jack
Post Whore
Yukon Jack's Avatar
I'd be a little surprised if 3k rpm is going to really damage your 305, if it is worn out then sure that isn't ideal. If I'm thinking right the gear vendor overdrive will knock your rpms down to about 2,400 to 2,500 at 65 mph, kick it up to 70 mph and you'll be not too far from 3k again.
If your 305 is tired, I'd definitely save the $3000 and put that towards a built motor, then go drive 65 and enjoy the sound :-)
I have to smile as I'm commenting on this as my 69 K20 gets to shaking a bit from the worn tires if I get over 55 mph - thinking about 70 mph in it makes me laugh, my bbc would be screaming and my tires would probably snap off.
Old 06-04-2009, 11:27 PM   #7
Reno's71
Ok, cool. I dont mind the sound either. Espesially when I get the exhaust done..
Old 06-04-2009, 11:41 PM   #8
skchevota
skchevota's Avatar
4.10s? , 700R4? just a few thoughts. i have an old moterhome with a 440 and 4.56 gears, its tires measure maby 30" . I cruz @70 no prob. But not to say that I wouldnt want overdrive. It just makes me less stressed when the engine is purring not whineing
Just remove the tack!!!!! then you wont know it is @ 3k lol...
skchevota is offline   Reply With Quote
Old 06-04-2009, 11:58 PM   #9
Eturnit3
Bloodied Knuckles
Eturnit3's Avatar
I hear that, with my 3.73's and original 3 speed... the only way Im hitting 70 is down a giant hill with a backwind
Eturnit3 is offline   Reply With Quote
Old 06-05-2009, 12:08 AM   #10
Reno's71
4.56 , th-350 Im just gonna roll with the flow..
Old 06-05-2009, 09:06 AM   #11
To answer the original question...
Q:Is a Gear Vendors unit "worth" it?
A:No
Q: Do I want a GV unit?
A: Yes
Q: Would I pay what a GV unit costs?
A: Yes
Q: Would I be happy with a GV even knowing I spent all that money?
A: Hellya
But,what I`ve come around to with all this o/d stuff is...
I want it in my 2wds that are meant for the hiway and long distance drives.On my 4wds I like tall tires and emphasis on being better off road.The taller tires bring my gearing up,so I`m better off on the freeway than stock already.The higher vehicle already has to deal with steeper driveshaft angles and I don`t want to add to that by sticking a gV in there.There is no o/d transmission built that stands up to a manual for durability,IMO.And,I really don`t want to roll along with all the cars on the freeway in my 40 years old truck geared for power and running bigass & heavy knobby old tires anyway.Let`em roll past.I`m in a real machine that requires more than just get in and go.
Old 06-06-2009, 04:58 PM   #12
gator2511
gator2511's Avatar
Talking Re: Gear vendor overdrive? Worth it?
I'm running a G/V in my 72 shorty 4x4. I have 3:73 gears with a TH400 tranny. At 75 mph I'm turning about 2100 rpms. For tires I have 32 x 11.5 x 15. I don't think you will ever save enough on gas to pay for the unit but it does make the cab quieter at speed. (Flowmaster super 40) At some rpms the mufflers really drone in the cab and I can shift into o/d and change it. Thats no reason to buy a G/V but I like mine. Is it expensive? Yes. Would I do it again Heck Yes! Low rpms on the road and turn it of in the woods. It does save on gas but you would have to do a lot of highway driving to make it pay.
gator2511 is offline   Reply With Quote
Old 06-06-2009, 05:06 PM   #13
gator2511
gator2511's Avatar
Oh yeah, I'm running a single piece drive shaft out the back with no problems ever.
Old 06-09-2009, 09:14 AM   #14
Benelli
Watchin the rust grow
Benelli's Avatar
How much did it cost for your TH-400?
I was silently thinking the same thing.....
1979 Chevy K10 (H/D Front end) - 350 w/ Holley Truck Avenger, Weinald Intake manifold, headers, bored .060 over, mild cam, Built up TH350 (TranStar Shift kit) with a part-timed NP203 t-case SOLD ($3,000)
1997 Chevy Silverado 1500 - 4.3 vortec, extended cab, 21 highway MPG, stock. "Red" SOLD ($3,000)
1987 Toyota 4wd Pick-up - work in progress, future DD SOLD ($1,850)
1998 Dodge Ram 2500 Cummins 5spd Quad cab - old 12 valve with some work done
2004 Chevy Silverado - Black, 4x4, 5.3L, stock for now
Underneath that rust is a heart of gold
Benelli is offline   Reply With Quote
Old 06-09-2009, 09:23 PM   #15
Skirkpat
Skirkpat's Avatar
From what I have read they are virtually indestructable, and I have seen multiple setups for less than half what you are talking for a new one? the last one was 1300.00 at the Shriners swap meet a few months ago, It was for a Ford though ( Different splines I think?).
I want one for my 2 WD 175" wheel base one ton, but no money = No O/D right now!!
Skirkpat is offline   Reply With Quote
Old 06-12-2009, 06:48 AM   #16
gator2511
gator2511's Avatar
I paid $995 for a built TH400 at Monster Motorsports. The Advance adapter for it was $628 plus I had to strip the transfer case and have the input bearing hole enlarged for the bigger bearing and shaft that came with the adapter. Add $2717 for the GVOD and About $4400 flies out of your checking account. But I WANTED IT AND NOTHING ELSE WOULD DO! Crazy, but I'm happy. It will run fast enough all day long to let the Florida Highway Patrol put me under the jail!
Old 06-12-2009, 01:10 PM   #17
Reno's71
Man, I really want one. Maybe I'll go with an overdrive trans. im gonna need a trans eventually anyway. No GVOD for this guy.
Old 06-16-2009, 08:15 PM   #18
72Cheyenne454
72Cheyenne454's Avatar
If you search, you can find a GV unit for a fair price. Like everyone else, I was in no position to pay $3K plus for a new GV unit for my 72 C20. After several weeks of searching on Craigs list, I found a complete GV unit for my Th400 for $1,000 bucks. I love the it. Gas mileage is not much better, but I can cruise at 80+ mph all day long and split gears for fun. An extra bonus is the reduction in cab noise (wife is much happier now). This was not the first unit I was able to find on C-List. I also found a GV to go behing my NP205 T-Case in my 86 K30. One last thing, my buddy just bought a complete, 1968 GMC runnning/driving 3/4 ton truck, one owner, 327, Th400. PS, PB, AC with a Gear Vendor Overdrive off of Craigs list for $800. Timing is everything.
72Cheyenne454 is offline   Reply With Quote
Thread Tools
Display Modes
