#1 | |
Bloo
how to mount the bottem of a short water pump alt?
i know how to hook it to the top bracket, now how do i hook up the bottem??
![]() the only thing i can see is bolt it to the exhaust pipe but i just cant see doing that.... which head bolt hole does the top alt bracket go in?
ASE Master Certified-GM Trained-Mechanic 1968 Chevy C30 157" WB Wrecker 1969 Chevy CST/10 SWB 1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed 1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205 1974 Chevy Custom Deluxe/10 1979 Chevy Custom Deluxe K10 farm truck beater 1989 Chevy K2500 Quote:
Fabricate till you "puke"
the trucks had a small cast bracket that mounted to the head, & the alt bolted to that.....i beleive that was 68-72(the 67s didnt have the accessory holes in the head, & used a stamped brackets like the cars had).....maybe somebody has some pics
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
My stock bracket goes in both of the wholes in the head. I really don't like it though, and I am ordering one of these tomorrow.
![]() From www.alangrovecomponents.com.
![]() ![]() 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
Bloo
ive got the top bracket that you adjust it with, but i cant find one for the bottem anywhere.... it looks like it must bolt straight to the end of the rams horn (theres 2 holes in it)
this pic of the old 305 shows how the top is mounted |
![]() Join Date: Dec 1999
69-72 have a cast iron lower that bolts into the front holes in the head,if you have early heads they dont have these provisions,aftermarket may not either.then the stamped steel adjustor.the 69 up trucks didnt use the bracket that bolts into the exhaust manifold.i have truck,car,style brackets available if needed,the style that bolt to side of manifold,and the kind that bolt to the front of manifold,and the correct truck ones.Im going to ebay them all soon,let me know if theres a certain kind you need.email me.
the alt bracket in the bottom picture is from before the heads had mounting holes and will not work with heads with the mounting holes
72 Chevy K10 Short Stepside 72 gmc K2500 |
its all about the +6 inches
josh, here is where the bolts go...
![]() And it'll look something like this... ![]() I can't place it on there quite right since my truck has the later style brackets. My steering pump is in the way. |
Blue 71,
I have a great picture of the bracket and setup, took it so that I knew how to put it back together on my "70. The file is to big (800K) to post here. if you want I can send it to you direct if you have a high speed internet connection.
Keith 70 CST longbed in progress. Hoping to get it back on the road soon. |
Bloo
i totally dont have the right set up then.... mine didnt have that bottem bracket... i have a 1 bolt top bracket and no bottem bracket i can find...
70 longbed, i would apreciate that pic mlbunch@scrtc.com |
Bloo
whoa woops wait you said high speed, i just have 56K dail up
longhorn ail isnt that a brkt for a long water pump? Mine bolted to the rams horn..had a heck of a time finding one to work with a short water pump..had to go to alan grove for a really cool brkt
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications click the clicky to join the site.... http://67-72chevytrucks.com/vboard/payments.php 67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44 Anderson,CA |
BigJim, Im the other longhorn(the crazy one!), but that is a bracket for the short pump alt. If you didnt have the acc bolts in the heads, you needed a stamped steel bracket that bolted to the waterpump & ex manifold. Desert rat had the yrs right on (69-72) on the cast bracket. the stamped bracket was older, but mounted the alt in the same position(just had a boss on the end of the manifold that the later manifold didnt have). the same set up that Longhorn pics on , is in my kids ranger(Ferd with a SB Chev).......the only way to do a ferd
#13 |
my badd....its been so long since ive seen a stock brkt it threw me off.
Jim
#14 |
Jim, I have73 up stuff on my longhorn, so have to think about the old stuff a little also! The kids ranger is stiill fresh in my mind(sorta)......it was only a couple yrs ago that I did that swap. the power steering pump bracket would make a preacher cuss tho, the pump is on the pass side
#15 |
Bloo
woo hoo!!! i dont have the right bracket, but i found one in my pile-o-junk that fit the holes in my rams horns and worked with the alt, i style wish i knew what i did with the correct peices though, now i need a huge (IMO) belt
#16 |
#17 |
Josh...I just got done painting that bracket y0u see in the pic...top piece too. It won't bolt to the caddy no matter how hard I try.
Whats it worth to you? |
#18 |
Then you'll be abl to install headers.
#19 |
Bloo
dont really know man, after rebuildign this thing i dont have much $$ left, you need any parts for the longhorn that i may have? i wont really know on the money sit. for probably a week or so, im trying to sell some stuff
#20 |
Bloo
also--- where does the top bracket bolt onto? mine bolts in one of the head bolts where your bottem bracket goes
#21 |
My upper bolts on the same way.
I'm int he same boat your in...tryin to get some $$ up for my truck. Can't think of anything you may have that I need. |
#22 |
Bloo
ive got a 6 cylinder im selling, told the guy $100 and he said he'd think about it, i hope he buys it!!! that could get these things going i think
so how much you wanting? ill make sure to write it down and try to save that much if i can |
#23 |
dunno what they are worth. make me an offer...I'll bump it up another 10 bucks
#24 |
Bloo
make an offer and youll bump it up 10 bucks huh? hmmm, ok hows about uuh
$ 0.50? ![]() |
#25 |
lol!
Thread Tools | |
Display Modes | |
