Old 06-10-2009, 06:01 PM   #1
rlcasey75
BoomerSchooner75
Simple question??? i hope
Ok what is the difference between 4h and 4h lock also 4L and 4L lock????? i am new at this 4 wheel drive stuff and trying to learn everything i can.
rlcasey75 is offline   Reply With Quote
Old 06-10-2009, 06:13 PM   #2
Eturnit3
Bloodied Knuckles
Eturnit3's Avatar
Re: Simple question??? i hope
hmm, good question. Im no expert and would love to hear an experts explanation. My best guess is that 4hi vs 4hi lock would be something to do with an independent front and rear shifting ( like this http://www.jbfab.net/ ), I know its referred to as "locking out the front" when you lock the front driveshaft, spin the rear tires to help position yourself for an obstacle, and vise versa for the front. Who knows tho, I may be way outta line and it could be the same thing...
Eturnit3 is offline   Reply With Quote
Old 06-10-2009, 06:15 PM   #3
Eturnit3
Bloodied Knuckles
Eturnit3's Avatar
Oh another possibility would be, if you switch your transfer case into 4hi and dont lock you hubs. that may be considered 4hi versus locking your hubs, which would be 4hi lock?
Old 06-10-2009, 06:22 PM   #4
rlcasey75
BoomerSchooner75
ok well i have a fulltime NP203 transfer case so i dont have locking hubs.
Old 06-10-2009, 06:25 PM   #5
Eturnit3
Bloodied Knuckles
Eturnit3's Avatar
and it shows a difference in shift pattern or what? I would think there wouldnt be any difference then between 4 low and 4 low lock but like I said Im no expert here... Im sure you'll get the explanation your lookin for, tons of knowledgeable guys on this site.
Old 06-10-2009, 07:05 PM   #6
Dooley
Dooley's Avatar
The full time four wheel drive 203 transfer case has an "interaxle differential",(planetary gear arrangement), that allows for the front and rear outputs to turn at different speeds.
Here, this it explains it better.
Dooley is offline   Reply With Quote
Old 06-10-2009, 07:10 PM   #7
Eturnit3
Bloodied Knuckles
Eturnit3's Avatar
thats the explanation you were lookin for.. learn somethin new everyday!!
Old 06-10-2009, 07:14 PM   #8
rlcasey75
BoomerSchooner75
ok yeah that helps thanks do you have a link to this or anything.
Old 06-10-2009, 11:30 PM   #9
72 CustomCamper
huh ???
72 CustomCamper's Avatar
Actually it's a Spider gear arrangement. There are no planetary gears in an NP203...
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 06-10-2009, 11:32 PM   #10
rlcasey75
BoomerSchooner75
ok so what does this mean
Old 06-10-2009, 11:56 PM   #11
72 CustomCamper
huh ???
Basicly you have 3 differentals in the truck. 1 in the front end. 1 in the rear end. And 1 in the transfer case. While in 4 hi or 4 low all 3 diffs are working. When you shift into 4 hi loc or 4 low loc you are locking the diff in the transfer case to send equal power to the front and rear ends...
Chuck
Old 06-11-2009, 10:42 AM   #12
rlcasey75
BoomerSchooner75
ok thanks that explains what i needed to know
Old 06-11-2009, 11:16 AM   #13
Prerunner1982
Prerunner1982's Avatar
In 4H and 4L you can go from dirt to paved roads without binding the driveline. The differential in the tcase allows some slip between the front and rear drivelines.
In 4H Lock or 4L Lock the front and rear drivelines are locked together and driving on pavement with cause binding and damage.
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 06-11-2009, 03:53 PM   #14
fun in dirt
fun in dirt's Avatar
Now that makes more sense!!!
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432
'85 K30 "Big Nassy"
[B]'85 C10 [B] "Corpse"
'01 2500 Suburban ...party wagon & tow truck
'06 Silverado SS...DD
'06 C1500 WT...DD
'07 Classic C1500 WT...DD
Built & sold cause can't keep 'em all:
'72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190
'55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938
'69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541
'86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619
fun in dirt is offline   Reply With Quote
Old 06-12-2009, 07:28 AM   #15
4h-loc/2H-loc = conventional 4wd without free-wheeling/locking hubs.
Thread Tools
Display Modes
