06-10-2009, 11:10 PM | #1 |
Power Steering Pump Pulley
Ok, I'm fixin' to have a Vintage Air set up put on my 71 non-factory air truck. The first issue that has come up is that my power steering pump has a press-on single-groove pulley on it. Where in the world can I get another pump with a 2 groove pulley? Any ideas or does someone have one they wouldn't mind getting rid of?
06-10-2009, 11:23 PM | #2 |
Hellasick
Re: Power Steering Pump Pulley
How many groves on your crank pulley? A/C usually runs off second one and PS off of third one.
I keep two MAGNUMS in my desk. One's a gun, and I keep it loaded. The other's a bottle and it keeps ME loaded. I'm Tracer Bullet. (Calvin and Hobbes) This life was a test. It was only a test. If this had been an actual life, you would have received instructions on where to go and what to do. RED meat is not bad for you...FUZZY BLUE/GREEN MEAT is bad for you!!!!!!!!!!!!! BUILT FORD TOUGH WITH CHEVY STUFF--sticker at Goodguys |
06-10-2009, 11:26 PM | #3 |
Currently, only two but I've already got that problem solved. The guy doing my install has a 3 groove crank pulley. He said that if worse comes to worse, I can run the belt for the compressor around the crank and power steering pulleys but I just don't want to take the chance of having the belt squeal every time I turn a hard corner.
06-11-2009, 03:50 PM | #4 |
Check the local pick-a-part and mid 70's cars. Also, I thought I saw an aftermarket chromed 2 groove pulley somewhere, maybe on Ebay. The aftermarket might carry one, even though I usually see the single groove one in chrome.
Thread Tools | |
Display Modes | |
