Old 06-16-2009, 12:08 PM   #1
LooseCannon
Bags rub when deflated
Is it common for convuleted bags to rub the spring pocket when fully deflated? Should I expect premature bag wear because of the "soft rub"?
The application is a daily driven 2005 Suburban that will be deflated/inflated 2x a day.
Front View
Rear View
LooseCannon is offline   Reply With Quote
Old 06-16-2009, 01:16 PM   #2
SCOTI
SCOTI's Avatar
Re: Bags rub when deflated
Everytime it inflates/deflates, it's rubbing. Anytime it rubs, theres wear. Anytime there's wear, there's a possibility for failure (sooner or later).
I would clearance the offending material ASAP.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-16-2009, 01:43 PM   #3
LooseCannon
Agreed.
My concern with removing the offending material is structural integrity. A LOT of material would need removed from the side of the spring pocket for clearance. I guess the question is how much material can safely be removed (I don't expect anyone to have the answer )?
Looks like I have 3 options:
  • run the bags as is, check for wear religiously
  • clearance the factory spring pocket and hope for the best <gulp>
  • fabricate an upper mounting plate to replace the factory spring pocket
Signed - Frustrated
Old 06-16-2009, 02:39 PM   #4
SCOTI
SCOTI's Avatar
Option #3 sounds like it's the safest, best planned approach. Try contacting Tony from ART & see what they might suggest.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-16-2009, 03:33 PM   #5
XXL
Señor Member
XXL's Avatar
And then replace the bags. The spots that have already rubbed are not going to repair themselves... they'll be a weak spot of unknown integrity for the rest of their lives. Don't find out how weak they were while tooling down the highway.
XXL is offline   Reply With Quote
Old 06-16-2009, 03:37 PM   #6
LooseCannon
He said it's fine because the bag is hitting a smooth surface while deflated.
Old 06-16-2009, 03:39 PM   #7
LooseCannon
I'm still in the process of converting to air ride so the vehicle has yet to leave the shop. Good suggestion though...
Old 06-16-2009, 03:56 PM   #8
SCOTI
SCOTI's Avatar
I'll bet if it was a warranty deal, the response would be different . I still think your safety warrants installing a better suited upper mount (especially since it's still in a shop environment). What diameter bag are they? Could you go smaller?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-16-2009, 04:01 PM   #9
cajundragger
heat the pocket ears up and beat them over with a hammer. you only need a little room so dont get too crazy.
where it rubs the lower mount its fine.
and remember, every oil change at the LEAST get under there and check the bags.
cajundragger is offline   Reply With Quote
Old 06-16-2009, 04:10 PM   #10
LooseCannon
Initially, I contacted ART hoping the sent bags were incorrect. Tony verified that they are the correct ones for the application.
I'm running the CoolRide setup. Not sure about the diameter or if a smaller size can be run and still support the weight of the vehicle.
Old 06-16-2009, 06:27 PM   #11
SCOTI
SCOTI's Avatar
That Tony guy..... For giggles, I opened up the PDF file for that kit & sure enough . .....
12. Double-check airspring clearance through full suspension travel. Rubbing will cause airspring failure and is not a warrantable situation.
It's in bold print in their own literature .
I like cajun's suggestion of heating & bending the 'pocket' lip for the necessary clearance. Seems that would be less invasive vs. cutting it completely out & welding in a new upper. It's worth a shot anyway.....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-16-2009, 09:04 PM   #12
Bazooka
Keepin it old school
Bazooka's Avatar
I would def not leave it as is thats for sure!
Bazooka is offline   Reply With Quote
Old 06-17-2009, 08:06 AM   #13
LooseCannon
I don't own a torch and don't think a butane torch (the ones sold at Lowes and Home Depot) are hot enough??? Maybe I can make pie cuts on the pocket, move the metal around with a hammer and weld it up to achieve the same results.
Thanks for all the suggestions guys.
Old 06-17-2009, 09:46 AM   #14
74STPSIDE
what if you went with a smaller dia bag with the same weight cap.?
74STPSIDE is offline   Reply With Quote
Old 06-17-2009, 01:21 PM   #15
gringoloco
A guy with a truck
gringoloco's Avatar
Mine did the same thing when I first installed it. There is some wiggle room in where the bags are located using the upper mounts. I moved them as far away from the clearance issue area as possible and solved 99% of it. I would still like to use a 2500 vs the 2600 bag to gain that last little bit, but I'm not sure the way the ART cuups are designed will allow this...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 06-17-2009, 01:45 PM   #16
LooseCannon
Thanks. Good to know I'm not alone. I sent Tony a note asking about the possibility of running a smaller bag. Hopefully there's another option (like using the 2500) available.
Thread Tools
Display Modes
