06-16-2009, 02:08 PM | #1 |
Broke a trailing arm...
Hey guys,
as the title states, last night I broke a trailing arm in half completely. I have attached a picture to show where it has broken. My truck is a coil rear 3/4 ton, don't know if it makes a difference (at time of install of a new arm it will) but thought I'd mention it. I need suggestions on where to find a new arm (if the junkyard is suggested, which trucks can I find an arm off of that will work?), and will also need help with the procedure of installing the new arm with basic tools and a floor jack or two (haven't been lucky enough to get any tools yet). Thanks in advance !! |
06-16-2009, 02:32 PM | #2 |
Re: Broke a trailing arm...
Simple to install, remove ubolts from axle, shock bolt, and the trailing arm attachment bolt. Any year 67-72 trailing arm will work.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
06-16-2009, 02:50 PM | #3 |
When I jack the truck up with a floor jack, I want to be lifting up the frame and body of the truck correct? (truck is sitting on the road right now...looking SICK slammed, but thats beside the point lol)
06-16-2009, 02:55 PM | #4 |
That's correct. You want to take the weight off of the rear coil spring and then everything should unbolt fairly easy. You might want to soak all the nuts and bolts with WD40 or PB Blaster for a couple of days....
06-16-2009, 02:58 PM | #5 |
Under Construction
im pretty sure the 3/4 trailing arms are slightly different, as they have a reinforcement plate welded on the end. a 1/2 might work, but i would look for 3/4. you want to jack it up , then put jack stands on the frame as you will need access to the rear of the truck to remove the ubolts and trailing arm....
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
06-16-2009, 02:58 PM | #6 |
My Carbon Footprint
Brother.....I'd really consider where you are if you are thinking about fixing it on the road. Is it on a hwy? It would be so sad to think of someone accidentally taking your life because they were texting on their phone and slammed into the back of the truck with you under it! I'd tow it home if you can afford to do that. If not....believe me....I've been there.
You will need to jack the truck up under the frame but you are also going to need a jack stand and or another jack to hold the weight of the axle. It can get a little tricky because you don't want to have the spring holding the weight of the axle when you try and loosen it. can cause some problems and a shift in everthing when she lets go. Ideally, try to just jack it up enough to take off the load so you can loosen the shock and the spring from the bottom. You can and should leave the spring bolted to the frame. Once that is done you can support the weight of the axle with a jack stand or another jack. I feel sorry for your arms when it comes to doing those U-bolts with a ratchet!!!! Just really think about what you are doing so you don't get hurt and really block/support the hell out of that truck before you get under it!!!!! Last edited by prostreetC-10; 06-16-2009 at 02:59 PM. |
06-16-2009, 03:06 PM | #7 |
PM sent. I can help you out.
2008 Chevy HHR 1/2 panel. 1949 Chevy Panel truck(just sittin, waiting) Board member #6 |
06-16-2009, 03:14 PM | #8 |
Car is on my residential street. No traffic cept my neighbors who know I constantly wrench in the street.
Also, the part of the trailing arm that is connected to the spring is the part of the arm thats literally on the ground, whereas the rest of the arm is still bolted to the rear end, which is about 8 inches above where the rest of the arm sits. When I go to install the new arm I will have to compress the spring to get the end of the arm to connect via U-Bolt to the rear end. Another floor jack for that? |
06-16-2009, 03:18 PM | #9 |
Under Construction
you dont have to compress the spring just get the arm high enough to put the ubolt in,bolt the spring to the arm. tight then install the shock.
06-16-2009, 03:30 PM | #10 |
perfect. sounds a little bit easier than I thought. Shouldn't take more than an hour or two with a friend and some beer at the end of the day waiting for us. haha
06-16-2009, 03:35 PM | #11 |
Seņor Member
Safety tip: just the ones on the truck.
06-16-2009, 03:41 PM | #12 |
Under Construction
heres a pic for your visual pre-planning...
06-16-2009, 03:50 PM | #13 |
awesome, that pic will help me alot. Thanks ::thumbsup::
06-16-2009, 03:58 PM | #14 |
My Carbon Footprint
Freakin' show off!!!! |
06-16-2009, 04:07 PM | #15 |
Under Construction
06-16-2009, 04:14 PM | #16 |
My Carbon Footprint
I'm pushing to have you banned because your avitar is not a 67-72 and any picture you post on this thread of a 67-72 is a "retaliation" picture and subject to a lifetime ban. Okay....I'm going to go get another beer now!
That was actually a good idea to show the chassis. I'd show a picture of mine but it looks like it's about to break too!!!! lol |
06-16-2009, 04:19 PM | #17 |
Under Construction
OUCH, the '56 in my AVATAR is my 1st love...... the 67-72 running a strong 2nd.... GIMME BEER
06-16-2009, 04:37 PM | #18 |
My Carbon Footprint
lol
06-16-2009, 04:42 PM | #19 |
side note* where in Bend are you at? I am there a few times a year. My family lives off Gift rd
06-16-2009, 05:16 PM | #20 |
Because the arm probably broke from being rusted I would count on needing a new set of U-bolts (a lot of them break trying to get them off). A decent spring or rearend shop should be able to make a set cheaply if you give them the dimensions.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
06-16-2009, 05:26 PM | #21 | |
Gone to greener pastures
Double your number & then go to the next larger time unit. Using your time estimate for an example; 2-4 days, & the job should be done.
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck Last edited by El Jay; 06-16-2009 at 05:27 PM. |
06-16-2009, 05:57 PM | #22 |
its all about the +6 inches
you may want to find a friend with air tools.
Knowing rust like I do, and knowing hand tools, you are in for a world of hurt if you think you'lll do it with a socket and rachet. |
06-16-2009, 06:26 PM | #23 |
Yeah... what LonghornMan said... I put an 8 foot pipe on a breaker bar to get one loose and it never moved! If you don't mind lunching the U-bolts, get a cut off tool. You'll be done in moments.
06-16-2009, 06:32 PM | #24 |
i would never even consider reusing u bolts from the rust belt unless they were only a couple years old.
I understand being broke... thats my life story. However, I'm sure you can apreciate the importance of keeping things in place back there... esp if you were going more than 15 MPH when it snapped. You also need to seriously consider swapping out both of those trailing arms. |
06-16-2009, 06:46 PM | #25 |
yeah this is what I'm figuring. She needs to be ready for another winter. I'll need her on the road for maybe another week total this summer while I do the engine swap and suspension on my Honda, and then she'll come off the road for an entire lookover and makeover.
Again, I appreciate the input a ton and I'm glad I'm aware of most of what you guys are stating (i.e. rust issues, U Bolts, timeframes etc). |
Thread Tools | |
Display Modes | |
