Old 06-19-2009, 03:15 PM   #1
1bad69camaro
What brakes interchange?
I have a 68 gmc SWB all manual drum. I heard local that 73 up discs fit if i use the whole spindle. Any truth to this? I am mechanically inclined and readily have these trucks in our junkyards. ANY info greatly appreciated.
1bad69camaro is offline   Reply With Quote
Old 06-19-2009, 03:41 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: What brakes interchange?
it is more involved than that, but yes, you can use front end parts 71 - 87.
The best way to do it IMO is swap out the entire front crossmember. this way there is absolutly no question what is what when you go to replace a front end component.
Old 06-19-2009, 04:12 PM   #3
LONGHAIR
Agreed 100%, everything is from the same year truck and there are no "custom" or "adapter" type parts involved.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 06-19-2009, 05:03 PM   #4
1bad69camaro
Is the crossmember a bolt in deal? Or is it the deal where you have to cut the crossmember out. can i just take the whole assembly lose on each side and bolt it in my truck?
Old 06-19-2009, 05:10 PM   #5
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
i think you may have to drill some holes in your frame to mount the diff. crossmember..but i may be wrong...
when i did the swap i useed spindles and disc stuff from 72 chevy...and just bought new balljoitns for a 72 truck and put em in my 68 a arms....used everything from pitman to idler arm bolted on and put new tierod ends on it bled brakes put a power booster bam
John
1999 Toyota Tacoma 4x4
Old 06-19-2009, 05:31 PM   #6
1bad69camaro
Is 72 different from 73 -87 stuff?
Old 06-19-2009, 09:28 PM   #7
LONGHAIR
It is a bolt-in deal...2 of the bolt holes are slightly mis-aligned and require some drilling, but the rest of them are right-on.
The most difficult part of the swap is figuring out how to support the engine and the frame at the same time.
Thread Tools
Display Modes
