Old 06-19-2009, 10:54 PM   #1
jerry moss
Born Psycho
jerry moss's Avatar
Question dana 60 u-bolt plate question
are the dana 60 u-bolt plates/ sway bar (front diff) any different than a big tube 44 front u-bolt plates/sway bar ? i have a set of u-bolt plates and sway bar in storage off a late 70s one ton 4x4 and was curious if there is any difference. i remember several years ago i checked on a set for a big tube 44 and about crapped myself when the dealer quoted me nearly 200 bucks for the pair.
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is offline   Reply With Quote
Old 06-20-2009, 01:21 AM   #2
whiskeydented
whiskeydented's Avatar
Re: dana 60 u-bolt plate question
I think the passenger side is different. The dana 60 only uses 1 u bolt on the pass side. The inboard mount is threaded in the pumpkin and the holes are not as wide as the u bolt. I guess you could slot out the dana 44 plate to make it work though.
whiskeydented is offline   Reply With Quote
Old 06-22-2009, 08:56 PM   #3
GM72K10
Next!
GM72K10's Avatar
Dana 60 and dana 44 spring plates. the second are from a 72 era truck, the first from a mid 80s K30
86 K30 CUCV M1028A1
86 K30 CUCV M1028a2 dually
86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump
More square bodies and CUCVs than I care to admit to
2020 Silverado K3500HD Work truck
GM72K10 is offline   Reply With Quote
Old 06-23-2009, 09:11 AM   #4
jerry moss
Born Psycho
jerry moss's Avatar
Thumbs up Re: dana 60 u-bolt plate question
thanks for the replies, looking at the pics it appears the 60 plates are definitly larger.
jerry moss
Old 06-24-2009, 11:30 AM   #5
johnnywagon
Sofa King. We, Todd, Ed.
johnnywagon's Avatar
Check out www.diy4x.com.
Only $40 for some killer aftermarket plates.
~John
71 Blazer One Ton
65 Chevelle Station Wagon x2
59 Belair 2 Door
71 Chevy Open Road Van RV
www.myspace.com/johnnywagon
johnnywagon is offline   Reply With Quote
Thread Tools
Display Modes
