Long-shot question
I'm just hoping someone knows.
I have a Getrag 360 transmission that I want to bolt up to a Chevy engine. Originally, it bolted to a Cummins. I know that Chevy uses Getrags, but I don't think they ever used the 360. Anyone know if a bellhousing from something else will fit the Getrag and make it hook to a 350?
my 2¢ - t.i.o.l.i. Bowen 1968 K20 fleet 1969 K10 swb fleet 1972 K10 Suburban 1972 C10 lwb step 1992 K1500 'burb 1995 K2500 'burb 1997 C1500 'burb 1999 K1500 2000 K1500 'burb Why do I own so many Suburbans? |
![]() Join Date: Jun 2000
And here's your long-shot answer:
![]() Dodge started putting NV4500s behind Cummins (in '94), and GM also had NV4500s starting in '92. From '92-'94 the GM tranny front case bolt pattern was different than Dodge's, but in '95 all NV4500s began using the Dodge configuration for the front case bolt pattern. SO MAYBE (here's your long shot) if Dodge kept the same tranny-to-bell housing bolt pattern for the NV4500s as they had with the Getrags (and I have NFC) then a 95-up GM bell housing should work with a Getrag. Worth asking someone, I think. Good luck. ![]()
Ben '68 Chevy C10 Custom LWB 327/TH400 2nd owner '16 GMC Sierra 1500 SLE Dblcab 4wd 5.3 |
Thanks, blu. I'll see if I can find that out!
Figure anything out? I'm curious if it'll work.
Thread Tools | |
Display Modes | |
