Old 06-20-2009, 03:30 AM   #1
79gmcc15
Gettin It One Pice At A Time
79gmcc15's Avatar
blower motor
is there a way to completely shut off the blower motor? mine is always running! even with the switches off and in the cold zone. it sure does make the truck hotter. lol its like its on really low setting.
RIP ELJAY
Work In Progress 1979 GMC C1500 Trailering Special.
Getting the truck done, one piece at a time.
“You can tell a lot about a fellow’s character by his way of eating jellybeans.”Ronald Reagan
“I don’t know the key to success but I know the key to failure is trying to please everybody.” Bill Cosby
79gmcc15 is offline   Reply With Quote
Old 06-20-2009, 04:25 AM   #2
dammitmitchell
the pollock
dammitmitchell's Avatar
Re: blower motor
are you sure you dont just have a vent issue? where maby the vaccum lines are screwed and leaving them open?
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 06-20-2009, 10:37 AM   #3
sperz1
sperz1's Avatar
Re: blower motor
You could pull the fuse, or better yet, disconnect the lead wire going to the motor.
sperz1 is offline   Reply With Quote
Old 06-20-2009, 11:16 AM   #4
S10Fan
Old Heap Driver
Re: blower motor
i know what you mean about the blower. I've been working in and around my dash the last few days, you're right, it runs every time the key is on. Thinking about a simple toggle switch, make sure it's a high amp switch, to turn it off. I don't want to pull the fuse,getting caught in the rain, no ac, i may need the defroster/blower.
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 06-20-2009, 12:22 PM   #5
dammitmitchell
the pollock
Re: blower motor
another one was a few years ago, my buddy on his 76 put the wrong vauums lines in the holes so his heatercontrols would only blow heat.... we did not notice this until we were on the HWY in the summer with the windows stuck up......
it sucked..
id check and fix the problem before jury rigging it...
jsut my two cents
Army vet 02-08
Old 06-20-2009, 12:57 PM   #6
ron350
ron350's Avatar
Re: blower motor
This old blower motor thread might help.
http://67-72chevytrucks.com/vboard/s...ghlight=blower
PilotJ had an easy fix.
“I had the same issue with my '79 ex-ac equipped c-20. There is a plug on the heater box under the hood that has a light blue, dark blue, brown, and yellow wire running to it. I just yanked the yellow wire and that just did away with the low speed. I still have medium and high-speed blower, but no low speed. Works out fine for me.”
Stock 75 C10 step side.
350 2 BBL, 350 trans. 150K miles.
ron350 is offline   Reply With Quote
Old 06-20-2009, 02:54 PM   #7
79gmcc15
79gmcc15's Avatar
Re: blower motor
Cant get cheaper then that! I'll have to look into that! That's funny that you found that. I did a search for Blower Motor and only came up with like 7 results and that was not one of them. Thanks!
it sucked..
jsut my two cents
Based on how much dust is in that area I highly doubt it has been taken out since it has been put in. but anything is possible, Thanks!
That is a good idea! thanks!
I was looking online because I was bored and I came across this! and it made me wonder if the relay could be broken?? or...? my truck does have "ac" but I took the belt off the pump because it didn't really work.
RIP ELJAY
Old 06-21-2009, 05:16 PM   #8
79gmcc15
79gmcc15's Avatar
Re: blower motor
anyone know the last question?
RIP ELJAY
Old 06-21-2009, 11:08 PM   #9
dammitmitchell
the pollock
Re: blower motor
the link dosent help.. it leads me to an autparts site asking my addy
and umm IIRC the relay is shorted out yes it can cause a constant hot to your blower..
but i would still check and see to make dang sure that the doors are operating properly...
just my .02
Army vet 02-08
Thread Tools
Display Modes
