Gettin It One Pice At A Time
so is this an "Expensive" sound?
it does sound like a loose valve but I am sure they are all tight and adjusted right. I checked some of them. the motor does have a miss in it. I just did the plugs, gaped them at 45*, I "think" the wires are OK. I did notice before that when it would click, it would miss then when it stopped it was OK. it sounds like its coming from up-top. also, what is that thing that is attached to the passenger side manifold? there is a rod that disappears in the back of the motor. could that be causing the clicking? the rod behind the *canister* is loose.
RIP ELJAY ![]() ![]() Getting the truck done, one piece at a time. “You can tell a lot about a fellow’s character by his way of eating jellybeans.”Ronald Reagan “I don’t know the key to success but I know the key to failure is trying to please everybody.” Bill Cosby Last edited by 79gmcc15; 06-22-2009 at 06:48 PM. |
Re: so is this an "Expensive" sound?
oh, I meant to re-phrase the last question. I know the rod that is connected to the "canister" is not making the noise. what I am wondering is what it was connected to, could be?
RIP ELJAY ![]() ![]() Getting the truck done, one piece at a time. “You can tell a lot about a fellow’s character by his way of eating jellybeans.”Ronald Reagan “I don’t know the key to success but I know the key to failure is trying to please everybody.” Bill Cosby Last edited by 79gmcc15; 06-22-2009 at 07:13 PM. |
Kid's Mechanic
sounds like the rockers need adjusted,The little vac canister is for a vacuum operated heat riser the rod should be connected to a valve in the exhaust between the manifold and exhaust pipe
to adjust them I can just start it up and loosen one till it starts clacking then tighten till its not then give it a 1/4 turn right?
RIP ELJAY ![]() ![]() Getting the truck done, one piece at a time. “You can tell a lot about a fellow’s character by his way of eating jellybeans.”Ronald Reagan “I don’t know the key to success but I know the key to failure is trying to please everybody.” Bill Cosby |
#5 | |
Low & Fast!
Yep...
Low & Fast!
And you may have a bad lifter for it to just start doing that. Did you change oil here in the past week or two?
yes I did, about 3 weeks ago.
Thread Tools | |
Display Modes | |
