Old 06-23-2009, 12:10 AM   #1
hotrod0688
Cutting Springs
I am wanting to cut the springs on my 69 c10 about 2 1/2 inches. Does anyone know how much spring to cut off to make it 2 1/2 inches? thanks
hotrod0688 is offline   Reply With Quote
Old 06-24-2009, 02:23 PM   #2
vexvader
1967 C10 SWB
vexvader's Avatar
Re: Cutting Springs
Hey,
I have not done it myself but I have read on this forum that 1 coil equals 1 inch of drop. That does not seem completely accurate to me because it looks to me like cutting 1 coil removes about 1 ½ inches of height from the spring. So my guess is that cutting 2 coils would give about 3 inches of drop. That is assuming that your springs are good (not worn out) and you are starting with the original height. I have seen old springs sag a inch or 2.
If it were me, I would cut 1 coil and then put it back together to check before I cut too much. I would be a lot of work but the best way make sure that you get the results you like.
If you do it, post your results so the rest of us can learn.
Thanks, VV
vexvader is offline   Reply With Quote
Old 06-24-2009, 03:21 PM   #3
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Re: Cutting Springs
I'm moving your thread to the 67-72 forums instead of the projects forum. You will get a lot better response there.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 06-24-2009, 03:31 PM   #4
hotrod0688
Re: Cutting Springs
I appreciate it, not real sure what im gonna do yet, I might just end up buying drop springs.
Old 06-24-2009, 03:34 PM   #5
my67chevytruck
Under Construction
my67chevytruck's Avatar
Re: Cutting Springs
you can get new drop springs for around 100 bucks or so. there are some on the parts board for sale as well.
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 06-24-2009, 03:36 PM   #6
glock35ipsc
Re: Cutting Springs
For what its worth, my personal experience has been (with good springs, not badly worn out springs) 1 coil will give about 2" of drop.
If your springs are old and/or worn, I would go ahead and get drop springs. They aren't very expensive like my67chevytruck said.
Bob
Old 06-24-2009, 05:16 PM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Cutting Springs
One man's budget part, is another man's whole buget.
If $100 bucks for new springs is out of the question, then chop off one coil, assemble, and measure. Drive it for a couple days before cracking it all apart again for more trimming since sometimes they'll settle a bit. Don't go bu what the tape measure says alone, take into consideration how it looks from all angles, how the tire to fender space is (possible rubbing) and how it rides.
Old 06-24-2009, 06:24 PM   #8
Shane
Shane's Avatar
Re: Cutting Springs
1 full coil usually equates to 2" - 2 1/2" of drop ...
Shane is offline   Reply With Quote
Old 06-24-2009, 07:29 PM   #9
pocketpool
Re: Cutting Springs
Be careful not to cut too much off or it will ride like a lumber wagon. When you cut the spring you also increase the spring rate.
pocketpool is offline   Reply With Quote
Thread Tools
Display Modes
