Old 01-04-2003, 04:06 PM   #1
bigd65
bigd65's Avatar
distributor question- not timing
where can i find the distributer gear shims. i checked O'REILEYs and AUTOZONE and got the same look from the HIGH SCHOOL KIDS that work there so i went to NAPA and guess what , they had a HIGH SCHOOL girl working there and the same look "wait a minute let me go ask" she says. well they dont have it eather. i checked my SUMMIT and my JEGS (both are my bibles) and i couldnt find them. any one have any ideas
2004 Silverado Crewcab
1972 Chevy Monte Carlo
2017 Chevy Tahoe
bigd65 is offline   Reply With Quote
Old 01-04-2003, 05:55 PM   #2
79BIG10
I'm back with 2nd truck!
79BIG10's Avatar
Jeff how about these?? Summit's Jeg's
1979 Chevrolet Bonanza Big10 "Tootsie Roll"
1985 Chevrolet Silverado (wife's)
Member of the Southern Bowties Club
"Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson
79BIG10 is offline   Reply With Quote
Old 01-05-2003, 04:00 AM   #3
87 STEPPER
STILL PLAYS WITH TRUX
87 STEPPER's Avatar
Jeff,
If i were you i'd get the yellow pg's out and call some local speed shop's and see if they have them!
I ck the link's 79big10 put up but summit shows they have them but they are listed as temp. unavailable Huh
And Jegs shows they carry them but they list for 4.95$ + s&h that means your gonna pay like 10 bux for some shim's.
Think about it bro that's insane
~~Bruce~~
MY 87 STEPPER
MY 99 2D/WD TAHOE
87 STEPPER is offline   Reply With Quote
Old 01-05-2003, 10:19 AM   #4
bigd65
bigd65's Avatar
yea i found them in JEGS, i am going to order some but i am also going to order a timing tape, so i can finally get my timig advance numbers.
2017 Chevy Tahoe
Old 01-05-2003, 10:48 AM   #5
pkbinplano
pkbinplano
pkbinplano's Avatar
If they are just shims get some shim stock and make them. Shim stock comes in a variety of thickness. If you need them asap or as a temp fix till you get replacements.
http://www.picturetrail.com/gallery/...7496&members=1
84 chevy silverado aka The Bananna Boat
pkbinplano is offline   Reply With Quote
Old 01-06-2003, 12:42 AM   #6
J-Spec C10
Whats this wire for?....
J-Spec C10's Avatar
Ok, so I gotta ask, what the heck do you need to shim the distributor for? I've never heard of this practice. Is there a significant benifit to doing it? Obviously its important if summit see's a need to stock them.
Kyle
CANADIAN CONNECTION
'82 C10 Resto-Custom--> * 2 1/4" manifold back dual exhaust with Hooker Aerochambers & High Flow Cats *Taylor Ignition Wires *Centerline 15" Telstars with 32"x10" mudders
J-Spec C10 is offline   Reply With Quote
Old 01-06-2003, 01:02 AM   #7
1976K5CHALET
1976K5CHALET's Avatar
I believe the spec from GM is 30k.....you can buy the shims from GM. Make sure you check the side play between the shaft and the housing.....the housing usually looses with age.
Azblazer
1976K5CHALET is offline   Reply With Quote
Old 01-06-2003, 01:30 AM   #8
87 STEPPER
87 STEPPER's Avatar
Shims are used to locate the distributor drive gear as near to center in the cam's gear to reduce wear on the gears and prevent binding of the gears most stock engines dont need them and the only time you may need to use them is after a manifold or cam change.
~~Bruce~~
MY 87 STEPPER
MY 99 2D/WD TAHOE
Old 01-06-2003, 02:06 AM   #9
1976K5CHALET
I'll agree on the first half of that comment...but the second...haven't pulled a large cap or small cap HEI yet without it having shims on it....i'll check the manual on the 30K....the 30K is for the first half of your post.
Azblazer
Old 01-06-2003, 03:36 AM   #10
J-Spec C10
J-Spec C10's Avatar
How do you check to see if you need to use shims? Would you need them if the engine has high mileage to compensate for wear? If I replace my cam in a 305, would I need to shim it?
Kyle
CANADIAN CONNECTION
Old 01-06-2003, 08:23 PM   #11
bigd65
bigd65's Avatar
well the reason i am shimming mine is because the center plate on my distributor lifts about 1/8 -1/4 after the advance weights are maxed in turn giving me waaaay to much advance at WOT
2017 Chevy Tahoe
Old 01-06-2003, 09:58 PM   #12
J-Spec C10
J-Spec C10's Avatar
I think I get it. I guess if my advance is way out at wot I'll know where to start.
Kyle
CANADIAN CONNECTION
Thread Tools
Display Modes
