Old 06-28-2009, 09:37 AM   #1
CG
BlahBlahBlah
Big block accesory brackets
I looked at a 69 yesterday with a big block and factory air. All the air brackets on the engine were gone.
Curious what seems to be the going rate on a set of brackets to bring this back to stock so I can hook up the air again.
Old 06-28-2009, 10:43 AM   #2
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
Re: Big block accesory brackets
Just look in the major catalogs like LMC Truck, GMC Pauls....etc. You can also go on eBay and look around. I'm guessing not cheap those since I sold a triple groove crank pully alone and got $113 for it. It was for short water pump those and I don't think that's even what you are talking about. Maybe the later year stuff works? Don't know cuz my A/C is both windows down and 80mph!
prostreetC-10 is offline   Reply With Quote
Old 06-28-2009, 10:46 AM   #3
Livrat
Member #1049
Livrat's Avatar
Mark, The going rate for a complete set is around $250
Livrat is offline   Reply With Quote
Old 06-28-2009, 11:40 AM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
To add to what Liverat said... it is highly recomended that they all come off the same vehicle.
Old 06-28-2009, 12:19 PM   #5
CG
BlahBlahBlah
I shoulda kept the ones off that old burb I sold a couple years ago =)
Ok, thanks guys. I still need to negotiate final price with this guy on the truck. I needed some ideas on price so I can make him a fair offer for both of us.
Old 06-28-2009, 01:29 PM   #6
Longhorn Man
Old 06-28-2009, 10:22 PM   #7
Skirkpat
Skirkpat's Avatar
I have a set from the truck 402 below that I put in my old 69 SS Chevelle, They are not worth a whole lot to me (definately not $250.00) Get some pics of the brackets you need and I will dig through the basement, maybe I can help a guy out in these financially troubling times
Skirkpat is offline   Reply With Quote
Old 06-28-2009, 10:29 PM   #8
CG
BlahBlahBlah
Wow, thats very generous of you. If I make the deal Ill definatly talk to you about them. I should know by tomorrow.
Mark
Old 06-28-2009, 10:31 PM   #9
3kidsnotime
3kidsnotime's Avatar
If you switch it out to long water pump they are cheap, if you stay with the short water pump they can get real expensive.
3kidsnotime is offline   Reply With Quote
Old 06-28-2009, 11:39 PM   #10
Longhorn Man
that set up would require swapping to the long water pump, running wires to the other side of the engine, and possibly a custom fan shroud
Old 06-29-2009, 10:34 AM   #11
Skirkpat
Skirkpat's Avatar
Are you talking about the setup on the engine I posted above?
I just looked at it a little closer, isn't the A/C compressor on the passenger side on 67-72? If so I will have the more common drivers brackets I think, I will look tonight and see if I can find them...
Old 06-29-2009, 01:03 PM   #12
Ont67shortbox
I just put a BBC in a 67 got all the brackets from Alan Grove Components,they are an excellent fit,look nicer than stock and not that expensive.Can paint,powder coat or chrome after you fit them.
Ont67shortbox is offline   Reply With Quote
Old 06-29-2009, 11:49 PM   #13
Longhorn Man
That is correct, that is not the proper 68 - 71, nor the correct 72 big block truck parts. that is the long water pump set up that places the Alt on the wrong side, the a/c on the wrong side, and the power steering in the wrong location.
It'll ge the job done, but it isn't just an install it and go set up.
Thread Tools
Display Modes
