Old 06-28-2009, 08:33 PM   #1
69stepside4x4
69stepside4x4's Avatar
How much trouble am I asking for?
I am flying in to VA on Friday to pick up my new '69 C10 4x4 (see attached photos) and as soon as I get it back to ATL, I want to start looking to convert it from the stock manual 3sp to a TH350 or TH400. I have found a couple t/c and tranny combos on Craigslist but most don't include crossmembers, lines, etc.
How much trouble am I looking to get into if I find a good condition t/c and tranny but have to piece together everything else? Any examples of your own swap over would be appreciated.
Mac
69stepside4x4 is offline   Reply With Quote
Old 06-29-2009, 07:24 AM   #2
Re: How much trouble am I asking for?
All the swaps I`ve done were using complete assemblies.It`s just the easiest way.
Old 06-29-2009, 09:33 AM   #3
beechcreek
I just got thru with this: I put a 208 tc behind a 350 turbo and i had a 3 spd on the column. Along with this i installed a 6" Tuff Country lift kit. I used the same cross member, But had to have spacers between the cross member and the trans mount and then spacers between the cross member and the frame to clear the front drive shaft. I had to buy the front and rear drive shafts, and there is some adapters and blocks that go between the trans and the tc i had to buy. I bought hydraulic lines to run from trans to trans cooler. Had to buy the cooler it wasn't that much but still had to buy. Bought a Lokar shifter for the floor, (they are not to cheap) that i'm not completely happy with but will have to work for now. Got to have a longer speedometer cable. Different fly wheel, starter, tourqe converter, all the bolts, and alot of other odds and ends. For me it was like i was running into problem after problem but it was probably just lack of experience, and not having what i needed there to keep working. But with patience and time i am now finished. Well almost i will probably have to cut the spring brackets off the front end and rear end to get the right drive shaft angle and then re-weld back on.
beechcreek is offline   Reply With Quote
Old 06-29-2009, 03:23 PM   #4
72 CustomCamper
huh ???
72 CustomCamper's Avatar
What part of VA are you coming to?
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 06-29-2009, 09:20 PM   #5
69stepside4x4
Thanks BeechCreek for all the info, sounds like a lot I could learn from your troubles doing this without finding a complete swap over donor A/T. Chuck, I am headed back home to Waynesboro in the Shenandoah Valley where I grew up...... I can't wait!
Chuck
Old 07-02-2009, 06:17 AM   #6
FLDBRED
Have you considered using the 700r4,it has a lower first gear and of course the overdrive!
FLDBRED is offline   Reply With Quote
Old 07-02-2009, 04:26 PM   #7
Tim Christian
Tim Christian's Avatar
I have a complte set up from a 72 Blazer that I am going to part out if interested. Thanks Tim
Tim Christian is offline   Reply With Quote
Old 07-03-2009, 07:43 PM   #8
69stepside4x4
Tim,
Good to know, I will call you early next week when I get my truck home from VA (picked it up today and I am psyched!)
Thread Tools
Display Modes
