Old 06-29-2009, 09:30 AM   #1
3quartertime
My Mistress the Sea
3quartertime's Avatar
56" rear springs up front
I've read that 56" rear springs from a later model will give a 71 a bit of lift in the front. I've located some from a 79 locally for a price that won't kill me. ( meaning if it doesn't work I won't be losing a bunch of cash!).
How much average lift would one expect? What is involved in the swap? Parts etc...
I searched and didn't find anything specific. If there is a thread that covers this please give me a search clue if you can...
Thanks!
,,,they'd look alot better as beer cans...
'71 K20 350/350 Rusty but trusty... gone
'70 C20... gone
'88 K1500... gone
'90 C1500... gone
'91 C2500... gone
'95 C3500 6.5L Dually love this one!...
3quartertime is offline   Reply With Quote
Old 06-29-2009, 04:56 PM   #2
Gene
Gene's Avatar
Re: 56" rear springs up front
Thanks!
You'll need the FGB52 kit from diy4x.com Should get about a 4 inch lift.
Gene is offline   Reply With Quote
Old 06-29-2009, 11:17 PM   #3
Captainfab
60-66 Nut
I agree, plus unless you are looking for a lot of flex, I would go with some 52's instead of the 56's.....just my .02
Old 07-01-2009, 09:51 PM   #4
ericpost
ericpost's Avatar
I just did this.
Got a FGB52 w/6" shackles from DIY in front and moved my rear springs which were 52" to the front. I then used the DIY shackle flip with 6" shackles on reverse side and put 56" with a +2" lift (compensate for the reverse side) in the rear. I got what I figure to be about 6" over all and she is riding on 38's. I got ALOT of help from folks on this forum. Here is a picture of how she sits
72 GMC Jimmy, 350, sm465 np205 (getting a face lift)
64 Nova SS, 327 SC & gassed, TH350. (blowed it up)
84 HD FX frame,80 FL tins, evo with 85hp/90tq (wifes bike)
96 HD FatBoy evo with 102hp/100tq (mine!)
KEEP NOTHING STOCK!
ericpost is offline   Reply With Quote
Old 07-02-2009, 04:58 PM   #5
Gene
Gene's Avatar
Hey Eric,
How many leafs did you use from the back? Did you move all of them to the front? I am limited because of the length of my u-bolts to 3 springs.
Thanks,
Gene
Old 07-02-2009, 06:46 PM   #6
3quartertime
My Mistress the Sea
Thanks for all the feedback guys!
That lift looks great Eric!
Got another question now. It looks like this lift would be a bit cheaper depending on how much you had to pay for the springs. Is that the main advantage over a regular lift kit or is there another reason to go this route?
Thank!
'70 C20... gone
'88 K1500... gone
'90 C1500... gone
'91 C2500... gone
Old 07-02-2009, 07:18 PM   #7
ericpost
ericpost's Avatar
Hey Eric,
Thanks,
Gene
All of them, I went to my local shop and had a new set of ubolts made for $35 including the proper nuts and washers... well worth the $$.
FYI: I go to a commercial truck repair shop. They make everything and it is wicked cheap and very high quality! I just got a completely new front drive shaft custom made with all the heavy duty goodies for $370
KEEP NOTHING STOCK!
Old 07-02-2009, 07:43 PM   #8
ericpost
ericpost's Avatar
Thank!
Going this route provides more flex off road and improves the getting to the dirt ride quality. If you really want to wheel rather than pose this is the way to go. I noticed the additional flex right away.
I went with superlift springs from JC Whitney. I think they were less than $350 and I know I got free shipping... which is very important when buying real heavy stuff.
Do a little research on DIY4X stuff. If you've torn into stuff before you should get a good feel for the amount of work involved. It will certainly be more than a standard lift but in the end you will be glad you did it. Depending on the tools in your shop (torches or plasma will certainly help with the rivet removal) it really shouldn't be that much more work unless your retarded like me. I went and add more steel to the frame and cross braced etc.... Really sort of un-nessarry but I can point to my rig and say I have just a little more...
Also when you start doing the math in terms of how much lift you are going to have it's going to seem way out of whack... A guy on this site called Grendal convinced me to go this route... I did and the truck came out awsome. I think VT Blazer is also running this setup as well.
OH and I removed the helper spring from the REAR spring pack and moved the it to the FRONT spring pack.... This is temporary and is there to help level the truck until the rear springs settle.
Okay one more tip, go with the DIY4X greaseable spring bolts! Quite possibly the best idea I have seen for the money.
KEEP NOTHING STOCK!
Old 07-02-2009, 09:20 PM   #9
3quartertime
My Mistress the Sea
That's exactly the information I was looking for!
But then of course it leads to more questions!
I don't think the work would be a problem. I think you may have answered my concern, but I just wanna make sure I understand ya right. I would consider my truck a work truck. Haul the boat, pull the utility trailer,etc... It's my main driver now, but I don't expect that to continue. I like the looks of 35's and would like to only go as far up as I absolutely have to. I like to be able to use the bed and it gets hard to find a hitch drop that isn't crazy at some point. I have some old humvee 36's on the back now and it clears fine for me. So I think 4 inches of lift is all I'd want to consider.
I'm thinking what I've learned here is that a standard lift kit would work best for me?
Thanks,,,
'70 C20... gone
'88 K1500... gone
'90 C1500... gone
'91 C2500... gone
Old 07-03-2009, 10:55 AM   #10
ericpost
ericpost's Avatar
Thanks,,,
Yep a standard 4" lift should be fine up to 36". You might get a little rubbing w/36's at full flex but it does not sound like that is going to happen much or ever given your use. You'll won't rub with 35's.
KEEP NOTHING STOCK!
Thread Tools
Display Modes
