Old 06-30-2009, 12:58 PM   #1
74 C-30
Dually Pride
74 C-30's Avatar
noob clutch question
alright so im rplaceing the clutch in my truck. 350, sm465, 2wd. any tips or tricks i should know? does the shifter come off the tranny with out pulling the top plate?
i know basicly what im doing but anything to make this process easier would be wonderful
Thanks!
If I have to explain, you wouldn't understand.
'74 Chevy C-30 350/4 speed/dually
'94 Ford Ranger
74 C-30 is offline   Reply With Quote
Old 07-01-2009, 08:24 AM   #2
James McClure
One shot, one kill.
Re: noob clutch question
74. There is a "bayonet" type cover over the base of the shifter you have to remove then the stick will just lift out. Do it in neutral. I use water pump pliers and it ain't easy. Open the pliers just large enough to fit above the lip at the top of the cap. Push down HARD and turn counterclockwise until you feel it hit a "stop" then let it up and lift stick out. When reinstalling, set stick back in easy and make sure the shift ball sets down in the neutral slot then reverse the above. Good luck.
1984 K20 350M engine with 465,000 miles. Well, it's finally done!! Almost 2 years of work, but it was really worth the effort. Little stuff left to do is mount winch, wet sand & buff out and build belly pan\running boards. Body work takes lots and LOTS of beer!!!! God, Guts and Guns made America and God, Guts and Guns will preserve it! The worst thing you could do is get into my sights, but that don't matter, you'll never know it, cause you'll never hear the shotJim or Paladin whichever you choose.
James McClure is offline   Reply With Quote
Thread Tools
Display Modes
