06-30-2009, 09:48 PM | #1 |
D44 carrier ?
Can I put a ring ,pinion and carrier out of a 3/4 ton D44 into a 1/2 ton D44?
07-01-2009, 12:09 AM | #2 |
Re: D44 carrier ?
I believe that you can yes.
http://www.cardomain.com/id/rcflyer1234 http://www.youtube.com/user/liftedtruck77 |
07-01-2009, 07:30 PM | #3 | |
Re: D44 carrier ?
They are only different from the knuckle out-ward.....but, it is not as simple as unbolting parts from one housing and bolting them back into another. There is a lot of precision measuring and fitting involved, plus some very specialized tools...and it's even harder with "used" gears. It helps if the person setting them up is also the one who takes apart the donor axle, but that will probably cost you more money though.
I always recommend seeking a professional for ring/pinion set ups. It's just not a job for the average guy. Most people will only ever need to do this once and it's just not worth the investment of one time. Pay a pro and get a warranty....but don't be surprized if they won't do used gears.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. |
07-01-2009, 09:44 PM | #4 | |
Re: D44 carrier ?
This is alot cheaper then a new set plus I need the carrier for the lower gears. Last edited by 1972CST; 07-01-2009 at 09:45 PM. |
Thread Tools | |
Display Modes | |
