Old 06-30-2009, 11:19 PM   #1
srsummers
Which Pitman arm do you use for PS conversion?
When converting my 65 to a 1976 power steering gear box do I use a 1965 factory Pitman arm or could I use the much less exspensive 1976 Pitman arm?
srsummers is offline   Reply With Quote
Old 06-30-2009, 11:51 PM   #2
protrash64
Resistance is Futile
protrash64's Avatar
Re: Which Pitman arm do you use for PS conversion?
I believe its the newer pitman.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 07-01-2009, 12:29 AM   #3
Captainfab
60-66 Nut
Use the newer one that is for the power box.....and be sure it is for a 2wd and not a 4wd. Although if you happen to have gotten a 4wd box the 2wd pitman are won't fit.
Old 07-01-2009, 12:36 AM   #4
slepysal
slepysal's Avatar
yup use the newer one
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Thread Tools
Display Modes
