Old 01-05-2003, 10:39 AM   #1
Jason Roberts
tranny down shift problem
can anyone tell me what the wire connection on the side of my 350 turbo is it will not down shift untill I bring it under 25 mph.
where is it supposed to be hooked up?
Jason Roberts is offline   Reply With Quote
Old 01-05-2003, 03:45 PM   #2
low 84
low 84's Avatar
if the connection is on the dirver side of the tranny, then you probly have a lockup torque converter. what is does is above a certain speed it locks the engine and transmission up solid trough the torque converter. this gives you better gas milage on the highway becuase your input shaft on the tranmisson is turning exactly the same speed as the engine, with the converter not locked up the tranny does not get 100% of the power from the motor due to the inefficientcy of the torque converter.
with this being disconnected your transmission just won't lock up at higher speeds, which dosen't hurt anything, alot of th350's are like that from the factory. it shouldn't effect your downshifting either. i think your problem is somewhere else.
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 01-05-2003, 09:41 PM   #3
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Jason,
Is your downshift cable working properly? Is there any binding? Is it properly adjusted?
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 01-06-2003, 07:17 PM   #4
Jason Roberts
down shift is working fine. it will kick down when I push 3/4 down
just won,t gear down when I slow down until 25 mph.
Thread Tools
Display Modes
