07-03-2009, 11:44 AM | #1 |
screamin eagle
tilt conversion question
When I convert from non tilt to tilt do I use the spring at the bottom end of the shaft before the coupling ?
SCREAMIN EAGLE |
07-03-2009, 12:01 PM | #2 |
Moderator
Re: tilt conversion question
Nope
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
07-03-2009, 01:33 PM | #3 |
TILT COLUMN GURU
Yes you do that is the way they came from factory. it does keep lower bearing from popping out of place.
kevs_classics64 64 Impala SS Conv 72 Blazer 2wd 75 Jimmy 2wd 63 Belair wagon 02 Silverado ext cab. DD RIP EL JAY |
07-03-2009, 01:40 PM | #4 |
Moderator
I stand corrected. Neither of my trucks has the same spring at the end of the shaft that the non-tilt columns have. All I have on mine is the retaining clip that I thought holds the bearing in place??
Thread Tools | |
Display Modes | |
