Old 07-05-2009, 11:14 PM   #1
dan42
dan42's Avatar
Sway Bar Function?
O.K., I installed a front sway bar on my '67 today - it was really easy - I got it from the JY off a 1-ton, a 1-1/8" bar, and used the kit from ECE. Very nice install. But I have to say that I don't notice a whole lot of difference after driving it. I have 2" drop springs on the front. Could that be why? What exactly does the sway bar do?
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 07-06-2009, 12:11 AM   #2
mongoose
mongoose's Avatar
Re: Sway Bar Function?
the truck should be some deal flatter while cornering.. but the stiffer springs will also help in the same way.
-'73 c/10 - Low with Go - will be complete... probably never.
-'90 2wd Blazer - well... soon enough anyways.
-'84 SWB - the daily gas guzzler.
mongoose is offline   Reply With Quote
Old 07-06-2009, 01:30 AM   #3
Frizzle Fry
Frizzle Fry's Avatar
Think of it this way; when the outside tire moves up in relation to the body as you make a turn, the sway bar tries to move the other (inside) tire up the same amount. The bar is designed to twist when this happens and it wants to twist back to it's natural position (flat). That twist back force is transferred through the frame bushings to keep the body more level than it would be without it.
You won't feel much of a difference in a straight line, but you should feel it in the corners.
Frizzle Fry is offline   Reply With Quote
Old 07-06-2009, 07:59 AM   #4
72BlckButy
Tot Roddin'
72BlckButy's Avatar
x2... time to hit that roadcourse!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 07-06-2009, 09:18 AM   #5
dan42
dan42's Avatar
Got it - thanks for the explanation. It does seem to be a little flatter in the corners.
Philippians 4: 6-7
Old 08-06-2009, 04:26 PM   #6
djw32
What year was that one ton?
djw32 is offline   Reply With Quote
Old 08-06-2009, 04:34 PM   #7
hessian18
Gen III Power
hessian18's Avatar
I got my bar off a 1 ton, its a 1-1/4''. From what I understand the 3/4 ton's have 1-1/8'' bar.
I noticed night and day with my 1-1/4'' bar, It made the overall ride a little more harse on bumpy roads, Since now your independent arms are working more together LOL and fighting each other.
On the freeway is where I noticed it BIG time, in the wind with big rigs and windy flat areas the sway bar helped the handling noticeably.
It also helped huge amounts in "S" turns, its just quicker to react and really makes the rear end want to go slideways !!!!
---Bob---
'81 Long Box. 2005 5.3l Vortec and 2005 4L80e coming soon...
hessian18 is offline   Reply With Quote
Old 08-06-2009, 05:07 PM   #8
djw32
Hessian18,
Cool. What year was the 1 ton truck?
Old 08-06-2009, 05:25 PM   #9
Frizzle Fry
Any 67-87 one ton will work.
Old 08-06-2009, 05:43 PM   #10
hessian18
Gen III Power
hessian18's Avatar
The truck I got the bar from was a 76. Im not 100% if that was the factory bar or not, since it has grade 8 hardware and nylocs...
---Bob---
Old 08-06-2009, 06:02 PM   #11
ebfabman
On a lowered truck the center of gravity is closer to the ground so a sway bar's effect is less noticeable. If you want a smooth ride and don't corner hard, forget the sway bar. On the other hand...........
ebfabman is offline   Reply With Quote
Old 08-06-2009, 06:19 PM   #12
bmfpeterson
bmfpeterson's Avatar
When you decided that you wanted a sway bar what improvements were you looking for?
If you have the 2 inch drop springs in the front that would stiffen it up and maybe that is enough for you??
bmfpeterson is offline   Reply With Quote
Old 08-06-2009, 09:08 PM   #13
northern 85
northern 85's Avatar
Did you get the frame stands with it?
northern 85 is offline   Reply With Quote
Old 08-06-2009, 10:47 PM   #14
Frizzle Fry
The difference was like night and day for my 69 and that was simply going from a small bar to a 1.25" bar from a 73-87 1ton. The truck feels more confident, modern, agile, and corners with authority now. If you are not sure if it's for you maybe you can find a swaybar equipped truck to test drive. My 64 with no sway bar feels like a canoe around turns compared to the 69.
Old 08-07-2009, 05:00 AM   #15
northern 85
Could it be on upside down?
Old 08-07-2009, 07:54 AM   #16
LONGHAIR
The fact that it makes the rear "loose" indicates that you have too much front bar.....or you need one on the rear to even it out. The idea that "more is better" is not always the case. Add a rear bar to go with your front and you will see a huge difference.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Thread Tools
Display Modes
