Old 07-09-2009, 11:00 AM   #1
62 Bowtie
62 Bowtie's Avatar
nothing but air
Any ideas? I changed all my brake lines and master upgraded to disc I have not been able to get all the air out of the lines I bench bled the master and the prop valve adjusted the pedal rod to both inner and outer extremes is there a sweet spot or spec for the pedal Im using an air bleeder and still the pedal goes to the floor thanks Tony
62 Bowtie is offline   Reply With Quote
Old 07-09-2009, 11:16 AM   #2
70 Suburban
Rods
Re: nothing but air
Just keep an eye on it and gravity bleed them.
Just keepin it simple.
1965 C-10 Ext cab build. 350??(Does it count at 2 truck if I had to cut one up?)
1966 C-10 lwb 283 auto
1970 Suburban in pieces
1971 Blazer 4wd....restore someday. all factory CST
1972 Blazer 4wd parts truck still a roller
1972 GMC Sierra Grandee
1998 Chevy ext driver.
2005 F**D the wife drive...(cant fix women)
70 Suburban is offline   Reply With Quote
Old 07-09-2009, 12:14 PM   #3
jason65
Registerd User
jason65's Avatar
Re: nothing but air
When your bleeding the brakes move the pedel slow. Just keep bleeding it. It will get there. I started with the pedel rod on the short side and kept adjusting it longer till I got it where I wanted it. Do you have a leak thats letting air back in?
jason65 is offline   Reply With Quote
Old 07-09-2009, 06:09 PM   #4
62 Bowtie
62 Bowtie's Avatar
Re: nothing but air
How do I know if I have an air leak? I did check all my lines and connections for fluid leaks
Old 07-09-2009, 06:19 PM   #5
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Re: nothing but air
Alan's Classic is offline   Reply With Quote
Old 07-09-2009, 06:48 PM   #6
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Re: nothing but air
When we did my 89 Van. GM asks that you wait 13 seconds between pumps and that it should be one single pump and hold, bleed. We did this for two days. Then we pressure bled the system and got pedal. Next day no pedal. There was the most insignificant leak coming from the front connection on the master. We redid the double flare got it to seal. Got pedal. Gravity Bleed the system and see what happens.
Old 07-09-2009, 07:56 PM   #7
62 Bowtie
62 Bowtie's Avatar
Re: nothing but air
what is gravity brake bleeding
Old 07-09-2009, 08:30 PM   #8
TR65
TR65's Avatar
Re: nothing but air
What everybody else said and....
Make sure the pedal rod is not adjusted in too far, there should be a small gap when the pedal is returned, else the fluid can't return to the resevoir.
I had a bad caliper once that kept letting air in. Replaced it and immediately had full pedal after a short bleed.
Going from manual to power brakes I had to lower the connection to the pedal by one inch (drill new hole) to get the correct stroke and get the brakes to bleed correctly.
Gravity bleed. Just connect tube from bleed valve to a can, open the valve and let gravity pull the fluid through. It is slow but you just have to keep check and keep the resevoir full.
Good luck
TR
1965 C10 SWB Fleet
Two owner
LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880
TR65 is offline   Reply With Quote
Old 07-09-2009, 09:21 PM   #9
jason65
Registerd User
jason65's Avatar
Re: nothing but air
Usualy if air is getting in fluid is getting out. Did you have good flow while bench bleeding? If the master is bypassing you get no pedal. On some trucks you got to move the pedal slow. Some got to be running. Some you have to use half strokes. You got any pics of the master, valve, ect. It might help us help you if we could see the system.
Old 07-09-2009, 10:31 PM   #10
70 Suburban
Rods
Re: nothing but air
if you have a vacuum gun you can pull the fluid through.. if you have a harbor freight or northern tool you can get a vacuum gun. he he he
Old 07-09-2009, 11:43 PM   #11
62 Bowtie
62 Bowtie's Avatar
Re: nothing but air
Heres a pic thanks for the tips (hey that rhymes)
Old 07-09-2009, 11:56 PM   #12
protrash64
Resistance is Futile
protrash64's Avatar
Re: nothing but air
I'm not a brake expert....but have you pushed in the button on the prop to let the fluid thru? I was told this released the bias for bleeding. Dont know for a fact or not.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 07-10-2009, 02:40 PM   #13
MikeN
MikeN's Avatar
Re: nothing but air
The bleeder screws have to be at the top. If you have the calipers reversed (i.e. on the wrong side) the caliper bleeders will not be at the high point and you will never get the air out. Ask me how I know
MikeN is offline   Reply With Quote
Thread Tools
Display Modes
