07-10-2009, 10:51 AM | #1 |
drop spindles and rally wheels
This has probably been covered like a hundred times in the past, so sorry if this is a repeat. I didn't come up with anything by searching.
Just wondering if a 2.5" or 3" drop spindle will fit inside a stock 15" rally wheel. I'd like to lower my truck some to get it out of the clouds, but I have no future plans of air bags.
Stu- 1981 GMC Sierra Classic LWB 355- original 2 bolt block, 10.2:1, vortec heads, Comp XE268 cam, built by self in 1992 700R4-2000 stall with lockup, shift kit, Corvette servo 3.07 open diff- I need a 3.73 posi! 2nd owner since 1986 - 388,000 km and counting. 100k by the first owner and the rest by me. |
07-10-2009, 11:36 AM | #2 |
Next project: 1970 K10
Re: drop spindles and rally wheels
2.5" will be fine, but I have heard the 3" might lead to some rubbing issues. I've ran the 2.5" with rallys myself, but not the 3", so hopefully someone else will chime in soon.
Nice truck BTW, I love the color!
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE Last edited by glock35ipsc; 07-10-2009 at 11:36 AM. |
07-10-2009, 11:55 AM | #3 |
Thanks!
07-10-2009, 12:00 PM | #4 |
Gen III Power
Killer truck !
From what I have read around with a 3'' spindle you will have to "relief" or "grind" the lower a-arm to clear the rim (at full lock )and possibly take some off the top of the caliper to clear the rim. I totally dig the truck, My truck is a 81 long bed and I call it ol blue too !! Im still hunting for a sport bumper to replace my step like yours
---Bob--- '81 Long Box. 2005 5.3l Vortec and 2005 4L80e coming soon... Last edited by hessian18; 07-10-2009 at 12:01 PM. |
07-10-2009, 12:11 PM | #5 |
67-72 parts collector,…
4 inch backspace on the wheel is the issue.
I have used 2.5" and 3" drop spindles,... and if the wheel has a 4" backspace you will need to do some clearancing on the lower control arm around the ball joint area. It's not a big deal.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 07-10-2009 at 12:12 PM. |
07-10-2009, 12:21 PM | #6 |
Gen III Power
Great information lolife
I may drop mine soon if $$ permits ( and the ole lady ) ahahaha
---Bob--- '81 Long Box. 2005 5.3l Vortec and 2005 4L80e coming soon... |
07-10-2009, 12:51 PM | #7 |
I'm running DJM 3" drop spindles w/8" rallys all around. I had to smooth out the top of the spindle because it rubbed. All in all they look great and there was very little mod to get them just right. All I used was a angle die grinder and a carbide bit.
Kameron YESTERDAY IS HISTORY - TOMORROW IS A MYSTERY I'm a Middle ClASS HOLE 07.5 Dodge 3500 CTD -- Daily 73 C10 Factory BB SWB 2WD |
07-10-2009, 01:30 PM | #8 |
Gen III Power
Have a picture of you truck liveanimal ??
07-10-2009, 01:38 PM | #9 |
6.0 powered square
My wheels have 4 1/4 back spacing with 3" djm spindles and I just had to grind a little off the brake caliper ear
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
07-10-2009, 03:48 PM | #10 |
i just put 3'' drop spindles on my 1986 with rally wheels and had to grind the spindles,not much only about 1/8.wish the company i bought them from wouldve told me they wouldnt work with 15s
07-10-2009, 03:50 PM | #11 |
What brand?
Evan B. |
07-10-2009, 03:53 PM | #12 |
springtech..got them off ebay
07-10-2009, 09:05 PM | #13 |
Thanks for the input everyone. By the looks of it a 2.5" spindle just clears and a 3" requires some grinding.
07-11-2009, 07:22 AM | #14 |
70+ ( Old Skool Club )
If I used a 2 1/2 inch dropped spindle and 1" lower spring will 15 x 8 rallys rub on my 72?
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
07-11-2009, 08:48 AM | #15 |
my 3 inch drop spindles with a 1 inch coil rubbed pretty bad on stock rallies.thats why i ended up with 17's.i had to grind more than the lip.the area around the bottom ball joint was hitting.
" Never look up a dead dogs butt." |
07-11-2009, 09:14 AM | #16 |
I cant even tell if i have a 2.5 or 3 inch spindle.They are from belltech.
i had to grind of the lip of the lower a arm.the wheels rubbed at full lock but i haven´t rallies i have eagle 589 s. Volker
My little US vehicle parts business: http://www.thegearheaddepot.com/ Come have a look! ´81 GMC C 10, Spanish Red |
07-12-2009, 10:41 PM | #17 |
3" DJM Spindles Western Chassic Flip Kit 8" Rallys 275/60 15 - rear 255/60 15 - front
07-12-2009, 11:04 PM | #18 |
I have car A.D.D.
I have 3" spindles, and 2.5" springs. Running the stock rally wheels with 245/60/15 tires. And I had some rubbing on the spindle but it only needs to be knocked down a tiny bit. I worried about it at first but...have no fear, if 3" is the drop you want, grind the spindles to clear the wheels. You will be fine. Here is a couple I took today next to a wheat field. Hope this helps you decision.
-Gerald Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace. 61 GMC Suburban SOLD The 86 build thread SOLD Are you a Colorado member?Click here. |
09-07-2009, 06:21 PM | #19 |
.. !WAR FEDOR! ..
more input on your tire and wheel combo please?????
"san diego chargers #1" |
09-07-2009, 08:15 PM | #20 | |
Happy to be here
olblue81- If you don't mind doing a little extra work to make them clear, the 3" spindle is the way to go. It's much better to have spindle drop where you can rather than spring drop. The spindle will on effect the ride, whereas the shorter the spring the stiffer it becomes. Besides, you will want more later....
09-07-2009, 08:50 PM | #21 | |
Jeramy '84 GMC project truck '85 Chevy 4X4 SOLD '07 Chevy Trailblazer SS 5th Annual SHPHC Car/Truck Show Pics http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT |
09-07-2009, 11:38 PM | #22 |
I have car A.D.D.
Did you want more info on my set up? If that's what you wanted, here you go. It is a stock set of wheels. I have 245/60/15 Cooper Cobra tires.
09-08-2009, 12:32 AM | #23 |
.. !WAR FEDOR! ..
sorry about that man, what drop do you have? are those 15x8 all the way around??
09-08-2009, 09:29 AM | #24 |
I used a 2.5" McGaughy's spindle and a 1" drop Belltech coil spring that I actually cut a 1/2 a coil off of to set the front down where I wanted it. It is just a flip in the rear. I am running 15x8 Rally's w/ 255/70r15's all the way around with absolutely no rubbing. Oh, BTW, it rides great!!!
09-23-2009, 11:34 AM | #25 |
anybody have any clearing issues with a 7 inch rim on 3 inch spindles?
Thread Tools | |
Display Modes | |
