07-16-2009, 11:18 AM | #1 |
Bolt choices
i have a 66 c-10 that i am replacing the clutch in, (along with the motor) and im wondering if anybody knows if it makes a difference whether or not i use the original style bolt that has a shoulder or if i can use one that is threaded all the way up to the head.
im referring to the bolts that hold the clutch assembly onto the flywheel. |
07-16-2009, 11:38 AM | #2 |
Re: Bolt choices
You want it to be at least a Grade 8 bolt.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
07-16-2009, 11:41 AM | #3 |
Re: Bolt choices
see, thats the thing, i can use the bolts that GM gave me or the ones i have.
the GM bolts dont look like grade 8 bolts, but they have a shoulder, and the bolts i have are grade 8 bolts but they dont have a shoulder. decisions, decisions. |
07-16-2009, 12:14 PM | #4 |
Re: Bolt choices
bump
07-16-2009, 12:23 PM | #5 |
Re: Bolt choices
use the shoulder bolts. find them in a grade 8 if you can.
07-16-2009, 12:33 PM | #6 |
Re: Bolt choices
i am currently replacing the clutch in my grandpas truck and we can use either bolt. i replaced the clutch in my truck and didnt use a shoulder bolt. i did use a lock washer, though.
is there any reason that a bolt that was threaded the full length couldnt be used in this situation? if it gets torqued to 45 lb ft it wouldnt be any different than a shoulder bolt, right? |
07-16-2009, 12:37 PM | #7 |
Re: Bolt choices
I don't know why those are shoulder bolts, the clutch pressure plate assembly should be tight against the flywheel.
if it were me I would just use fully threaded grade 8 bolts....
CHEVY ONLY |
07-16-2009, 12:41 PM | #8 | |
Re: Bolt choices
THANKS TO EVERYONE!!!! Last edited by Green66Shortbed; 07-16-2009 at 12:41 PM. |
07-16-2009, 12:52 PM | #9 |
Re: Bolt choices
do I win a prize? hopefully, for your sake and mine, it is the right answer
CHEVY ONLY |
07-16-2009, 12:54 PM | #10 |
Re: Bolt choices
07-17-2009, 03:03 AM | #11 |
Re: Bolt choices
A Shop Manual is a must if you plan on doing any work on these old rigs. This should answer your question. As My Auto shop teacher Merv Hall use to say. "These automobile manufactures have spent thousands of dollars on research and development. What makes you think you can do any better". And of course we would just laugh and continue with our work. Anyway what I am getting at is use the shop manual and the Assembly Manuel. These will give you the correct information.
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi 1961 Impala SS 348/350 4-speed 3:70 Posi 1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed 1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear 1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc 1949 Transitier 3-wheel forklift Crosley 4-Banger 98' FXD 2002 2500HD |
07-17-2009, 03:59 PM | #12 |
60-66 Nut
Re: Bolt choices
Before I knew any better I used regular fully threaded bolts without issues. The factory bolts have the shoulder on them so that the torsional force from the pressure plate is against the smooth shoulder instead of against the threads on a fully threaded bolt.
07-17-2009, 04:39 PM | #13 |
Re: Bolt choices
Ah, makes sense guys.
Thanks when The OP was saying shoulder bolt I was thinking it would bottom out and allow the pressure plate to float, which I don't think would be a good thing.
CHEVY ONLY Last edited by joe231; 07-17-2009 at 04:41 PM. |
07-17-2009, 04:50 PM | #14 |
Re: Bolt choices
well with this new found knowledge, it looks like the trans and bell housing will be coming back off in the next few days. at least i found this out before i was cruising down the highway. lol. i do love the learning experience, though. thanks to all you you for your help. this place is awesome.
07-17-2009, 04:52 PM | #15 |
283 Drama Queen
Re: Bolt choices
Stress risers (including threads) under shear are not good things. Threads are to create compression load. Shoulders take shear much better.
For about 12 years of my adult life I had a severe speech impediment. My ex-wife never let me get a word in edgewise. |
07-17-2009, 10:12 PM | #16 | |
Watch out for your cornhole !
Re: Bolt choices
07-17-2009, 10:15 PM | #17 |
Re: Bolt choices
this, right here, is why i come here. *high five* is it an acceptable practice to just remove one bolt at a time and place a new one in there? should i remove them all and then reinstall and follow the pattern?
07-17-2009, 10:21 PM | #18 |
Re: Bolt choices
Do them one at a time and you will be fine. You might take a big c-clamp and cinch it down near each bolt to keep the pressure plate from warping away from the flywheel when you get the bolt removed until you get it replaced.
If it were mine, I wouldn't even do that though.
07-17-2009, 10:22 PM | #19 |
Re: Bolt choices
good idea
CHEVY ONLY |
07-17-2009, 10:25 PM | #20 | |
Re: Bolt choices
it wont be a problem to remove a bolt and torque it, then skip a bolt, remove the next one, replace and torque, skip, remove and torque, and so on, or would can that potentially cause some trouble? |
07-18-2009, 07:25 AM | #21 | |
Re: Bolt choices
07-18-2009, 09:22 AM | #22 |
Hollister, CA.
Re: Bolt choices
I dont think its that crucial in using a "shoulder" bolt in this application. On my clutch I used a 3/8" x 1" grade 8 bolt, washers and Locktite.
If you must run a shouldder bolt, you can but longer bolts (so you have a shoulder) then cut them down. However, all you would need is an 1/8 shoulder...mabey 1/4 at the most.
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
07-18-2009, 10:28 AM | #23 |
Re: Bolt choices
if the smooth portion is much longer than 1/8th" seems it would interfere with the clutch tightening to the fly wheel, which would be much worse than using a entirely threaded bolt, if the pressure plate assembly were allowed to float i would assume it would eat the bolts and wallow out the holes in a very short period, not to mention make some noise....
CHEVY ONLY |
07-18-2009, 10:48 AM | #24 | |
Re: Bolt choices
07-18-2009, 10:52 AM | #25 | |
Re: Bolt choices
the flywheel is threaded completely through it so the bolts can tighten as much as they need to. there are only less threads being used since the shoulder is about 3/8 of an inch long. that would make me think that i would want to use a fully threaded bolt rather than a shoulder bolt since i would have more threads working to hold the pressure plate to the flywheel. |
Thread Tools | |
Display Modes | |
